Old 08-27-2016, 09:53 PM   #1
slepysal
slepysal's Avatar
low buck hood lock
Here is a low buck easy to make hood lock.
I used some flat aluminum stock made some bends drilled two holes and attached them to the striker plate. I used an adjustable shackle pad lock to make it easier to pass thru the drilled hole.
You can remove your coil wire when you park it and then lock the hood and there is your anti theft.
Hope this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-27-2016, 10:12 PM   #2
kingburnett
Re: low buck hood lock
That is great. I have been thinking along the same lines as you except I planned to use some links of chain to help with the alignment of the lock!
I like More's Law 'If more is better, then too much is just right.'
http://s1238.photobucket.com/albums/...20chevy%20k10/
1971 Chevelle - sbc 350 TH350
1961 K10 - sbc 400 4 spd M/T short stepside
kingburnett is offline   Reply With Quote
Old 08-28-2016, 08:36 AM   #3
Mathew21
Mathew21's Avatar
Nice job. Thanks for sharing.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 08-28-2016, 10:54 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Awesome mod! I leave the windows up and doors locked and truck in gear on mine Makes it to where they'd have to break the glass to get in or move it. And since the truck is parked a few feet from my bedroom window it wouldn't be very long before I'd be out there. lol
Old 08-28-2016, 04:36 PM   #5
62stepside longbox
62stepside longbox's Avatar
Thanks for showing everyone this sal, I think I'll do it on my '60 hood
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 08-29-2016, 10:52 PM   #6
slepysal
slepysal's Avatar
Glad to help !
Old 06-16-2017, 01:49 AM   #7
slepysal
slepysal's Avatar
So with rvrfoots truck being stolen and a couple of security threads being posted,I thought this might be useful
Old 06-16-2017, 09:54 AM   #8
scoot_mcgrute
It's kind of hard to see but my truck had a similar setup put on it along the way. There are 2 metal tabs, one is on the latch and the other is on the lever, that have a hole in them for a padlock. Seems to be very effective if I were to ever use it.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 06-16-2017, 10:00 AM   #9
rvrfoot
I had a kill switch. Thay slim jim the door and pushed down the street.
rvrfoot is offline   Reply With Quote
Old 06-16-2017, 10:10 AM   #10
slepysal
slepysal's Avatar
Totally sucks
Old 06-16-2017, 10:18 AM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Gettin pretty bad when you have to use one of these at home:
Old 06-16-2017, 12:42 PM   #12
scuderia
scuderia's Avatar
I've got a similar setup on mine, works really well. Wondering if anyone has made something to padlock the E-brake on? That would make it tough to roll away... or tow.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 06-18-2017, 11:29 AM   #13
AnobleL74
i used your idea on my 66 and it works perfectly. to lock it up and as a safety backup latch.
AnobleL74 is offline   Reply With Quote
Old 06-18-2017, 12:41 PM   #14
AcampoDave
AcampoDave's Avatar
Besides using all of the above, I also use a motion sensing l.e.d floodlight and this little gem. https://www.harborfreight.com/wirele...tem-93068.html
AcampoDave is offline   Reply With Quote
Old 06-19-2017, 11:29 AM   #15
65chevysub
65chevysub's Avatar
I am thinking of one of the locks Classic Industries sells that goes around the brake arm. It's about $40 and since I will be moving to Tucson in a couple years I want my truck safe. Might even pull the coil wire at night as well.
It's called the Peddle Jack. Part Number UN1001A in the CI catalog.
65chevysub is offline   Reply With Quote
Old 06-19-2017, 11:49 AM   #16
rvrfoot
Thats a good idea. Pulling the coil wire or putting a kill switch on. will not work They pushed my truck down the street.
Old 06-19-2017, 12:06 PM   #17
jchav62
1962 C-10
jchav62's Avatar
Good post Sal. Anything helps in today's world. I like the padlock ebrake idea too.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-19-2017, 01:10 PM   #18
scuderia
scuderia's Avatar
Here's some photos of my setup took about 20 minuets to make. Even used an existing bolt hole in the hood. As for the E-brake after looking it would be easy to do simply drill a hole through the brake handle assembly in the on position but also easy to defeat.. unhook or cut the cable. Maybe if one was to use a security type fastener on the cable attachment then the crooks would be forced to deal with cutting the cable that can be a PITA if you don't have a cutoff saw.. Will continue to look into. Cheers.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 06-19-2017, 04:30 PM   #19
forestb
forestb's Avatar
I saw a 55 Chevy Bel Air chained to a tree. The car had no windows and it was chained to the b-piller.
forestb is offline   Reply With Quote
Old 06-19-2017, 08:05 PM   #20
AcampoDave
AcampoDave's Avatar
This truck was stolen from a friend of mine in Lodi, CA last year. Same as rvrfoot, they pushed it away. It was one of the few times he didn't block it in with his daily driver. We never saw hide nor hair of it again. These days you need to use layers of protection. Disconnect the power and lock the hood, use a club and a trailer wheel lock, get an alarm and/or a Lojack, and a motion sensing floodlight, but above all...have a talk with your insurance agent before you have any problems. If you don't have stated value coverage, get a professional written appraisal so you don't get jacked around. (My agent gave me a referral for an appraiser.) Too many of us are unsure about just how well covered we really are until misfortune strikes.
