Old 06-19-2017, 01:10 PM   #1
6768chevylover
6768chevylover's Avatar
rear hatch window removal/ gauge question
I have 2 questions, no relation to each other.. 1- How do you remove the rear hatch window on a blazer? In the trucks I know when you install its installed from the inside. 2- Can the stock instrument gauges work with a missing gauge?
6768chevylover is offline   Reply With Quote
Old 06-19-2017, 08:14 PM   #2
72k5ls
Re: rear hatch window removal/ gauge question
On the gauge cluster question all the gauges that are present will function perfectly normal. The one that is missing will just be an empty hole in the cluster.
72k5ls is offline   Reply With Quote
Old 06-20-2017, 08:35 PM   #3
notsolo
notsolo's Avatar
I removed my rear hatch window, no special tools. Hatch laying flat on the bench,( on a carpet pad ) Soap it up good, some small wooden or plastic shims work it out from the back side. Plastic putty knife under rubber, feed in shims to hold the rubber out on 2 sides carefully work glass and rubber out. I cleaned and reused all the rubber on mine. Cleaned and treated with Wintergreen oil and xyleen, Nasty stuff, it will eat regular rubber gloves.
notsolo is offline   Reply With Quote
Old 06-21-2017, 07:57 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Lacquer thinner will do wonders for rejuvenating old rubber. However, new rubber is available at a nominal cost.
Tom Vogel is offline   Reply With Quote
