#1 | |
Re: A/C System rebuild - what should I replace?
He said he would take my money if I insisted but that he felt the need for full disclosure.
#2 | |
![]() Join Date: Jun 2016
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
I knew after I typed that the question would be asked. I would have to go back through my notes on the project for the manufacturer. I found them through various online threads for people wanting a custom/built to spec condenser.
$113 in the link that I provided. Even less expensive through places such as RockAuto. Cheap upgrade to the 30 year old crust pieces that we all have. My stock one was fairly intact thanks to the dry desert climate but it was still 30 years old rusty and corroded. Nothing custom needed here - they are available off the shelf and ready to bolt in.
#5 | |
The local A/C shop recommended an AC Delco parallel flow condenser. I forget the part number but I think it will come up on a Rock Auto catalog search for your vehicle. He said the condenser will be a direct fit.
He also recommended a Sanden compressor but it would require a flimsy looking Rube Goldberg adapter bracket (like 3 separate pieces) for my 454 which I did not like, so I think I will just go will a new Alma A6 compressor. The shop owner has an 85 454 and he still has the original A6 in it but he says he just keeps replacing whatever the system needs since it is essentially "free" for him. |
