Old 04-10-2004, 11:06 PM   #1
Mountain Man
What to use to polish out old aluminum?
I want to see if I can bring back life to my 72 grill. On my 67 , I used Mothers alum. polish , and lots of elbow grease. Is there something better? Any recomendations?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 04-10-2004, 11:24 PM   #2
Sweet72
Sweet72's Avatar
No miracle chemical can replace elbow grease!
This will be easier to do with the grill removed from the truck. Use a buffing wheel in your electric drill motor with rubbing compound, and progressively finer grades of compound. Finish the job off by hand polishing with the mothers aluminum polish. Protect the new shine with a good quality paste wax.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-11-2004, 12:20 AM   #3
lock
Insert funny comment.
lock's Avatar
Use buffing wheels. I like to use tripoli compound and then jewlers rouge and then a common aluminum polish like Mothers. You can get aluminum to shine like a mirror with the right process.
here is a good link
http://www.gmtips.com/3rd-degree/dox.../info/info.htm
Here is some adpaters I did using this process. The top one is complete. the bottom is hand sanded to 1000 grit wet.
lock is offline   Reply With Quote
Old 04-11-2004, 12:26 AM   #4
Jeepster376
Jeepster376's Avatar
Don't forget the beer, a key ingredient for polishing aluminum.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-11-2004, 12:30 AM   #5
Jeepster376
Problem is the grill is anodized, so it can't be polished, only cleaned. Unless you sand or electic strip the anodize off.
Old 04-11-2004, 12:31 AM   #6
smitty62
smitty62's Avatar
A lot easier if you remove the anodizing chemically first.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 04-11-2004, 11:13 AM   #7
Faster_than_you
I picked up some stuff from satin gloss. I think that there metal polish is something out of this world! very awesome stuff. it removes oxidation, and other unwanted crap on your metal.
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 04-11-2004, 11:18 AM   #8
Big J
Its lookin' like a Blazer!
Big J's Avatar
You might try Blue Magic, I used it on my wheels and it worked better (easier, less elbow grease, lol) than the Mothers. Walmart and most auto parts stores sell it.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 04-11-2004, 11:23 AM   #9
Faster_than_you
well if you want to order some satin gloss metal polish here is some information I see on the bottle:
matt chemical
wearville, nc
dealer inquiries: 1-828-645-2870
To Reorder-1-800-843-9291
the retail amount for a 12 oz. bottle, which will be more than plenty for my lifetime, goes for about $19.95
mothers I think sucks big rocky mountain oysters, sorry mothers polish lovers. I had a 87 vette, yeah mothers polish stripped my finish on my valve covers. it also oxidized my paint.
hope this helps you on your polishing quest
~Christopher L. Orr
Old 04-11-2004, 12:13 PM   #10
Wootdog
Wootdog's Avatar
Polishing
If the metal is oxidized, to take pits out. Start with 320 grit sandpaper on a Orbital sander. Go to 600, 800, and then polish out with a cotton buffing wheel. Use Coker compound from James G. Morrison in Searcy Arkansas. It is yellow in color. Then use a polishing paste of Flitz. Available from Grainger. Use a wool pad. Buff until surface is black. Wipe off with a clean cotton rag. Put flour on the surface to remove any excess Flitz. The Flitz on the surface should be good for approximately 3 to 6 months. This is from Barry who polishes aluminum for a living. Wootdog
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 04-11-2004, 05:51 PM   #11
Faster_than_you
I started thinking about it, and thought that the polish will even shine up the scratches. so if you have scratches you might want to use sweet 72's advise, and remove the grille, and get all your scraches out using finner and finner grit sanding methods. then polish with ANYTHING BUT mothers polishing compounds.
good luck freind we all for your efforts on trying to salvage your grille. my old man was funny, my grille after I had him paint it, he took a chisel laid it flat on the grill then a hammer came into place. oh man I told him what the crap are you doing! he said what it is going to be taken off anyways. ohhhh it was in perfect condition intell he did that. I was pissed.
~Christopher L. Orr
