04-10-2004, 11:00 PM | #1 |
computer illiterate
bb frame mounts
whats the difference between 71 and 72 bb frame mounts? anyone got a pic?
72 2wd blazer 72 swb 4x4 |
04-10-2004, 11:26 PM | #2 |
72 look like newer clamshell mounts and towers, but are different
slightly on the mounts. |
04-11-2004, 09:21 AM | #3 |
computer illiterate
come on guys somebody has to have a pic of these parts. i found a pic of the bb 71 mounts now does anyone have a pic of the bb 72 mounts
04-11-2004, 10:46 AM | #4 |
look in lmc catalog it shows the difference
04-11-2004, 12:12 PM | #5 |
Careful, they attack...
The 72 mounts look just like the 73-87 small and big block mounts with only slight differences.
04-11-2004, 12:33 PM | #6 |
Found this using the search feature. I think it has what you are looking for. Good luck
http://67-72chevytrucks.com/vboard/s...g+block+towers |
04-11-2004, 01:16 PM | #7 |
Roadtrip!
Pic of 72 mounts. Hope it is good enough to see.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-11-2004, 01:18 PM | #8 |
Roadtrip!
Not letting me post pics right now, will try again later...
04-11-2004, 03:16 PM | #9 |
good pics on the above link.
04-11-2004, 03:49 PM | #10 |
bb
mount pic
04-11-2004, 04:46 PM | #11 |
computer illiterate
can you tell me what year the ones i have are
04-11-2004, 04:47 PM | #12 |
computer illiterate
er
04-11-2004, 06:28 PM | #13 |
Yours are the 73-87 type. They will still work but you will have to drill a hole for the rear bolt on the top of the frame. Other than that, they will be the same. They will use the rubber mount for a 73-87 instead of a 72 (slightly different). I had a set of them I was going to use and then bought a frame with the 72 mounts already in it. If you're not worried about it being year-correct, then use those ones. They are worth about $35-45 to resell. The 72 mounts are more like $100, so you are saving money this way and have the same type mount.
If you want, I can sandblast and powder coat them chassis black for a very good price for you. |
04-11-2004, 07:43 PM | #14 |
Pic of BB 1972 only frame mounts...note the one rib for reinforcing compared to the 73 up two rib reinforcing and the slightly different hole pattern
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
04-11-2004, 10:18 PM | #15 |
computer illiterate
wanna trade rod?
