Closed Thread
Old 06-26-2017, 12:40 PM   #5526
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Originally Posted by flashed View Post
Andy ,that is just too Kool ,love it .
Thanks man!
They are easy to install. They come with a small hole saw bit to mount them.
Here are the ones I got.
http://www.ebay.com/itm/2x-LED-Car-D...53.m2749.l2649
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 06-26-2017, 12:44 PM   #5527
flashed
I will have to consider that soon once I get some medical issues out of the way ,thanks for the info ,you are always great about sharing your projects .
John
flashed is offline
Old 06-26-2017, 06:11 PM   #5528
NoStopN
NoStopN's Avatar
Originally Posted by hewittca View Post
I am also debating on running thin white lines now that the sidewall is smooth, and tested out the look with chalk.
Whew. I missed this last line & was worried that you might have used that flapper wheel or some other grinder to dig down to the layer of white. The thin white line looks good. You could go with a red line too.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 06-26-2017, 08:45 PM   #5529
rsgt
rsgt's Avatar
I did some trimming on the front coils to get the rake I like so much.
rsgt is offline
Old 06-26-2017, 08:50 PM   #5530
Stephen717
Stephen717's Avatar
I ziptied a USA-1 plate to the grille (not bolted on but in place) and painted the front bumper white to match the top and rear bumper.
Stephen717 is offline
Old 06-26-2017, 09:47 PM   #5531
Blakeman350
Blakeman350's Avatar
I pulled a set of electric fans out of a 04 Monte Carlo and with some minor fab work and two temperature controls I got them in today. I set one fan to come on at 180 and the other at 200. I drove it around in traffic this afternoon when it was about 85 outside and the truck never broke 210 degrees.
Blakeman350 is offline
Old 06-27-2017, 09:33 PM   #5532
CST10
CST10's Avatar
I love those ol school rakes. Looks great.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 06-27-2017, 09:47 PM   #5533
B Myers
B Myers's Avatar
That looks great, you're not alone on the rake.
B Myers is offline
Old 06-28-2017, 06:31 AM   #5534
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
If you seal up around the fans to the radiator it should help even more. Buy some black foam at Lowes are wherever you choose and place in between the radiator and the fans. Force the air through the radiator not around it.
Andy4639 is offline
Old 06-28-2017, 10:22 AM   #5535
Blakeman350
Thanks for the tip, I'll definitely look into that.
Old 06-28-2017, 04:35 PM   #5536
ghalperin
ghalperin's Avatar
I went to Brothers Truck Show last Sunday
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 06-28-2017, 05:02 PM   #5537
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Removed my alternator and took to our local Starter/Alternator rebuild shop. Its a 37amp and the owner tells me he can make it a 55 amp which will be good for my purposes. Another item off the checklist before I do the Power Tour in 2019..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 06-28-2017, 06:13 PM   #5538
Andy4639
Old member
Andy4639's Avatar
I have done 3 HRPT in my C10. I hope to make my 4th in the 64 SS Impala next year.
Andy4639 is offline
Old 06-28-2017, 09:21 PM   #5539
Already Gone
I thought you were goona ay you want to do it in with the ramp truck
Old 06-29-2017, 08:43 PM   #5540
1968aj
installed a new tach cluster. installed new headliner. kind of mocked up rest of interior to see how it looks.trying to decide on whether to go with the white or black. still trying to decide on what color to paint truck
1968aj is offline
Old 06-30-2017, 12:26 PM   #5541
azle
Yesterday, installed a thermostatic fan controller. Works Great!
Azle
azle is offline
Old 06-30-2017, 03:37 PM   #5542
Big Block
Big Block
Big Block's Avatar
Put in my new carport.
Big Block is offline
Old 06-30-2017, 04:31 PM   #5543
70STOVEBOLT
70STOVEBOLT's Avatar
Not today, but the other day I replaced the "stock" carb mounting gasket on my 402 with a 1/4" thick insulator gasket, and now the fuel does not boil out of my Edelbrock carb after it sits for more than 10 minutes while hot. Hard to believe such a small thing could make such a huge difference. I am running the stock cast iron intake with a 1" aluminum spacer/adapter. If you have an Edelbrock carb and have this issue, get an insulator gasket and your problem will be solved. I used Fel-Pro p/n 1908.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 06-30-2017, 05:06 PM   #5544
rmr_69c10
The previous owner had the center link on backwards, and the tie rods had seen better days. So, got all the old stuff removed and got the center link off. Now to put it back together the right way with new parts tomorrow. Should handle a little better once done...
rmr_69c10 is offline
Old 07-01-2017, 12:03 AM   #5545
Old_Gold
Old_Gold's Avatar
I finally finished the new wood floor in the truck this week!
Now I just need tho work on a new "rest of the truck"...
Old_Gold is offline
Old 07-01-2017, 11:06 AM   #5546
NoStopN
NoStopN's Avatar
After searching Ebay, I found that dually caps had logos with a black background. I didn't like that as much as I liked the silver back of the caps I already had. So, I joined everyone else & got spacers.
NoStopN is offline
Old 07-01-2017, 01:40 PM   #5547
66clow
66clow's Avatar
Went to a Saturday get together at garage one pro shop in Tampa. Met a fellow 67-72chevytrucks.com guy in his awesome Blazer. On the way home passed this awesome back drop and had to take some photos.
66clow is offline
Old 07-01-2017, 01:56 PM   #5548
VWNate1
VWNate1's Avatar
@ syfygi : yes these were very common military trucks when new .
lots and lots of good works here ! .
me, i badly crashed my moto monday and have been in he hospital all week .
still dreaming and planning to finish and drive/work/enjoy my truck though .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-04-2017, 02:45 PM   #5549
ohboy321
ohboy321's Avatar
I bought a transfer case shift boot from Custom/10 last August, and finally got around to installing it today. I cleaned and painted both rings, and ran the screws under the wire wheel. For vintage hardware they cleaned up pretty good and have no rust on them. My F*rd had rusting hardware before it left the lot in 2008.
Also installed a new firewall wire gutter. I will start installing new front leaf springs next weekend.
ohboy321 is offline
Old 07-04-2017, 04:29 PM   #5550
aventur1
aventur1's Avatar
Was in Melba Idaho 4th of July Parade
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Closed Thread
