Old 06-27-2017, 08:57 PM   #1
rsgt
rsgt's Avatar
More air flow for the A/C condenser
While fixing my A/C, my pressures were a little high unless I could keep my condenser cooler. I made an aluminum panel to cover the gap above the condenser. Without it I would put my hand in front of the condenser and couldn't feel much air flow. With the panel I could really feel the air coming through. I did keep an eye on my engine temps and there was no change there. I have been driving it around and everything is working good. I will be painting the panel black.
rsgt is offline   Reply With Quote
Old 06-27-2017, 09:02 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: More air flow for the A/C condenser
Great idea
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-27-2017, 09:12 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: More air flow for the A/C condenser
Air flow is a main player when it comes to AC pressures and cab temps! I would suggest you block any openings around the shroud to force the air movement through the shroud and not around it under it are as you have seen above it.
If you notice the AC temp going up at a red light you can add a electric fan to keep the temp down.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-27-2017, 09:51 PM   #4
rsgt
rsgt's Avatar
To really seal things, I put push on door seals around the edges of the shroud.
Old 06-28-2017, 08:34 AM   #5
1972RedNeck
1972RedNeck's Avatar
Looks like you still have the stock condenser. What refrigerant are you running? R134a? If yes, you would benefit from upgrading condensers...
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-28-2017, 10:03 AM   #6
rsgt
rsgt's Avatar
I am using R12
