Old 01-15-2017, 10:57 PM   #1
manimal
manimal's Avatar
Trans problems...I have codes, need help.
Ok, I just picked up a 93 C3500 5.7/4L80E 2wd. The guy drove it 60 miles to my house and it ran great...or at least shifted fine...until today.
I have been working on the truck, fixing the tail light harness, removing old stereo system wiring, new headlight switch,etc...
The truck had a miss bad, so I changed the plugs(2 of which were destroyed), and the CTS was bad, so I changed it too.
I took it out for a test drive and it would not shift out of first!!! WTH? also my speedometer was NOT working....so I pulled some codes.
These are the codes I pulled;
15,24, and 83.
Also my "BRAKE" light is on. Any help would be GREATLY appreciated.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 01-16-2017, 08:44 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Trans problems...I have codes, need help.
Code 15=coolant temp sensor circuit
Code 24=VSS circuit
Code 83=TCC Solenoid Fault
Your PCM isn't getting VSS Signal. It could be the VSS, DRAC Module, or wiring problem.
Is there any possibility you damaged any wiring not related to the stereo you removed?
95 S_Trucker is offline   Reply With Quote
Old 01-16-2017, 09:48 AM   #3
manimal
manimal's Avatar
Didnt take the cluster out at all. Just put on a new bezel, got the stereo adapter trim. The wiring I removed was an old amp power wire and speaker wires that ran under the floor, and some dead end switches that were mounted on the dash bezel.
-Lance
Old 01-16-2017, 09:58 AM   #4
sntrym95
sntrym95's Avatar
Sounds like you disturbed or cut a ground that affects those circuits. I would retrace what you removed. Check your fuses too.
Mike
sntrym95 is offline   Reply With Quote
Old 01-16-2017, 10:18 AM   #5
95 S_Trucker
The VSS code has nothing to do with the cluster.
Check the brake fuse. Its 15A. The DRAC gets its power from that fuse.
Old 01-16-2017, 10:22 AM   #6
manimal
manimal's Avatar
Already checked all fuses. NONE of the wires I removed were attached to anything, just loose.
-Lance
Old 01-16-2017, 10:45 AM   #7
95 S_Trucker
Check the connections at the DRAC. There's not a lot to this system. There's a speed sensor, the DRAC, the PCM, and the wiring between them.
Old 01-16-2017, 11:18 AM   #8
manimal
manimal's Avatar
Thank You, I will go out and check them.
-Lance
Old 01-16-2017, 01:19 PM   #9
manimal
manimal's Avatar
All connections are good. I disconnected the battery and cleared the codes. After 15min or so I reconnected the battery and started it. The "BRAKE" light was still on, so I took it out, still would not shift. Brought it back. Neighbor asked if the speedo was working or not, I pulled codes and only got "83" this time, I took it back out to check speedo and the truck worked flawlessly this time???? Whats with that?
The only thing I did different was jiggle the ignition key a litlle, very minor turn and the "KEY BUZZER" comes on, turn it forward and it goes off, but that is the only thing I did different.
Could the ignition switch be the culprit?
-Lance
Old 01-16-2017, 08:35 PM   #10
manimal
manimal's Avatar
well, it's back to not working. So I backed it into its spot for the night and turned it off. and then just for Sh*ts and giggles, I started it back up and the brake light went out and the speedo worked again.....????
Could this be an ignition switch problem?
-Lance
Old 01-18-2017, 09:40 PM   #11
manimal
manimal's Avatar
Well, I thank you to the "2" people that did try to help. Maybe if this would have been a big budget build it would have gotten more activity. Thanks anyway. Gonna head on over to GMT400, GMFS and FullsizeChevy.
-Lance
Old 01-18-2017, 10:04 PM   #12
95 S_Trucker
No need to get upset that people can't fix your truck for you over the internet.
You have an intermittent problem. It could be caused by anything in that diagram, from a faulty sensor to a little chaffed wire or a corroded terminal or a bad module. These problems are hard to find in person.
Old 01-19-2017, 10:15 AM   #13
manimal
manimal's Avatar
Trucker, like I said, I appreciate your help greatly. It gave me a place to start. I dont have the manuals for the gmt400's yet, but will soon. Thank you again.
-Lance
Old 01-22-2017, 10:46 PM   #14
manimal
manimal's Avatar
I fixed it...Thanks!
-Lance
Old 01-22-2017, 11:11 PM   #15
sntrym95
sntrym95's Avatar
What was the issue?
Mike
Old 01-23-2017, 08:04 AM   #16
95 S_Trucker
Yes, we'd like to know. And it could help other people in the future that have a similar problem.
Old 07-01-2017, 10:36 PM   #17
manimal
manimal's Avatar
Turned out to be a ground issue. I ran a ground from the harness ground on the intake to the frame. Problem solved. Sorry it took so long to respond...I forgot all about this thread.
-Lance
