Old 06-18-2017, 10:04 AM   #1
gramps77
Anyone have Vision wheels on their square?
Looking at these wheels. The price is great https://m.summitracing.com/parts/vsw-1438873gmml6
gramps77 is offline   Reply With Quote
Old 06-18-2017, 10:21 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Anyone have Vision wheels on their square?
I've seen those style wheels on squares..vision wheel is just up the road from here
Old 06-25-2017, 12:02 AM   #3
Jay2Cor517
Jay2Cor517's Avatar
I was looking for some gray wheels when I stumbled across this thread. So I went to the Vision website to take a look. I was interested in the staggered look particularly--20x8.5s front with 20x10s rear. With this setup, the common suggestion is to go 4.5" backspacing on the front and 5.5" backspacing rear. Well, Vision has the fronts in those size but for the rear, they only offer 20x9.5" wheels with either a 5.25" or 5.75" BS . So that leaves me with the question, which backspacing should I use for the widest possible tire, give the best look and still tuck. I run 275-45-20s now, hope to eventually push 305s or 315s. My rear drop is somewhere in between 6 to 7" on a '86 short wheel base. I'm not sold on any particular wheel just yet. But was thinking, what if another wheel I do like comes only in the same type configurations? Any thoughts?
Vison Wheels http://www.visionwheel.com/wheel/6855/2831/
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 06-25-2017, 10:47 PM   #4
Tetanus Express
Tetanus Express's Avatar
For the 20x9.5 I would say the 5.25 backspacing which will put the tire and wheel a 1/4" more to the inside. Tucked a 1/4" more is what I meant. It will let you run a little bit more taller tire with a little bit more sidewall bulge and not rub. But of course that would still need to be verified.
Tetanus Express is offline   Reply With Quote
Old 06-27-2017, 02:16 PM   #5
ms2335
ms2335's Avatar
18x8.5 w 245/45/18 up front
18x9.5 w 275/40/18 rear
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 06-27-2017, 10:08 PM   #6
Jay2Cor517
Jay2Cor517's Avatar
Thanks Tetanus for the input. And MS2335 that's a good looking truck, is it yours?
Old 06-28-2017, 05:29 AM   #7
ms2335
ms2335's Avatar
Thanks, yes I is my daily driver
Old 06-28-2017, 08:17 AM   #8
gramps77
Originally Posted by ms2335 View Post
Attachment 1665308
Have you tried the rear up front? How much more clearance do you have with that 245 up front now?
Clean fricken truck by the way
Old 06-28-2017, 09:42 AM   #9
ms2335
ms2335's Avatar
thanks
I haven't tried the rears up front but with the 5.25 backspacing they should work alright. If you have the 1.25 rotors on the front, you have to run a shim on it or remove the dust caps and clearance the hub. I have the 8.5 on front with the 5.12 backspacing (I think that is it), they sit in about an 1 or so under the fenders. I run a 5/16 shim from autozone with longer lugs for hub clearance.
Old 07-01-2017, 04:13 PM   #10
gramps77
Are you having to run a shim now? Or are you saying if you tried the rears upfront?
Old 07-02-2017, 12:43 AM   #11
RUN GMC
RUN GMC's Avatar
US Mag makes a version of that wheel in 20 X 10...its called the rambler......
http://us-mags.com/rambler-u111-w-6133.htm
RUN GMC is offline   Reply With Quote
Old 07-02-2017, 01:08 AM   #12
gramps77
yes I saw those, but they are about $70 more per wheel
