Old 06-16-2017, 09:35 PM   #1
Harley03joe
TBI Has Anyone Used These
TBI Has Anyone Used These Im Going To Go Tru My TBI Check The Injectors And Clean It Up, I Was Told That The Fuel Pressure Should Be 9 To 13 PSI
Let Me Know If Anyone Used These Parts OK
Thank You For Any Reply
Harley03joe
This fitting will replace the TBI inlet fuel nut and provide a place for your fuel pressure gauge attachment. Dimension of attachment is 1/8" NPT. Fitting comes with special OEM type teflon washer. You will be able to use your OEM fuel line.
Part # 62-FP
86'-95' TBI Fuel Pressure Adapter Fitting
This Tbi Adjustable Regulator is needed for stock and modified GM tbi engines. At 3/4 to WOT the computer uses a fixed program for max power. Therefore,since it is not reading the A/F ratio you may need more or less fuel for maximum power. This regulator let's you change what the computer can't.
Includes installation gaskets and instructions.
Part # 62-FR
86-95 GM TBI Fuel Adjustable Fuel Regulator (with gaskets)
86-95 GM TBI Fuel Pressure Gauge
Part # 62-PG
86-95 GM TBI Fuel Gauge
Harley03joe is offline   Reply With Quote
Old 06-16-2017, 10:12 PM   #2
Brennan
Re: TBI Has Anyone Used These
I have, multiple times. The adapter requires slight modifications to the hard fuel line , (just a slight tweak to the bend). One word of advice: keep a close eye on that fuel gauge, mine failed and puked gasoline all over the hot engine while driving. Scared me enough to install a gauge that used an electric sending unit.
Brennan is offline   Reply With Quote
Old 06-16-2017, 10:18 PM   #3
Harley03joe
Thank You For The Come Back, Boy That Was Fast.
I Will Check The Gage Often And Might Just Plug It Off After Its Installed
What Did You Think About This Item Does It Work Ok ??
And Thank You For The Fast Comeback
Harley03joe
Part # 62-FR
Old 06-17-2017, 01:15 AM   #4
kwmech
I would recommend reading this first, good information
http://tbichips.com/?page_id=73
Old 06-17-2017, 07:56 PM   #5
Brennan
Harley03joe
Part # 62-FR
My application is different than most, my tbi system is heavily modified and custom tuned. My previous Truck was much closers to stock and did benefit from increasing the fuel pressure, (because the truck would run lean at WOT before the fuel pressure increase)
Hope this helps
Old 06-17-2017, 10:57 PM   #6
Harley03joe
Hope this helps
Thanks For The Info
Old 06-19-2017, 03:50 PM   #7
kalbert
Ditto.
kalbert is offline   Reply With Quote
Old 06-20-2017, 12:11 AM   #8
Harley03joe
Originally Posted by kalbert View Post
Ditto.
Sorry Kalbert
To Much For Me To Read And Understand, All I Wanted To Know Was Did Anyone Use >>>Part # 62-FR
86-95 GM TBI Fuel Adjustable Fuel Regulator (with gaskets) And What Did They Think .
Sorry But Thanks For Your Input
Harley03joe
Old 06-20-2017, 11:09 AM   #9
Mattchu60
I will start by saying - I have not used this gauge. I have the handheld gauge which I put into the line with an adapter. Its sort of a pain to use - as you have to go under the truck, loosen the fuel line, put adapter in, check pressure, then remove the adapter again. I also have dual exhaust which makes that space pretty cramped to work in.
But I would rather do that vs having the gauge in the line all the time right on top of the engine.
If you are running a stock engine, I don't think you really need this - that's my $0.02. Probably fine with the stock regulator psi. But if you want to modify the engine, then its not a bad idea.
Mattchu60 is offline   Reply With Quote
Old 06-21-2017, 01:54 AM   #10
Harley03joe
Boy I'm Trying To Get The Fuel Line Lined Up Now Its Not As Easy As It Looks
Going To Work On It Again In The Morning
Harley03joe
Old 06-21-2017, 01:57 AM   #11
Harley03joe
Harley03joe
Old 07-02-2017, 03:06 AM   #12
Harley03joe
Hope this helps
Thank You
And About FhotoBucket I Left Them & Went With Flicker
Harley03joe
