Old 07-01-2017, 08:08 PM   #1
davepl
davepl's Avatar
Stalling with AC in a 1970 402
I don't like to keep my idle too high (about 500 in drive), but sometimes that's not enough to keep the engine from stalling if I have the AC on high and do a tight turn, for example... the accessory load will stall the engine sometimes.
There's no "idle kicker" or solenoid on the 1970, so I'm wondering:
a) Does anyone else experience this?
b) Can a later model solenoid be retrofitted easily?
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-01-2017, 09:35 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Stalling with AC in a 1970 402
Anything can be made to work...
What carb and manifold ?
The "kicker" solenoid just bolts to a carb stud and nut, plus a lock pin,,,wired in relayed parallel circuit energized when A/C is turned on....
In my mind, 500 is a bit low...maybe try 650 hot and see how it goes...
Have fun...
AussieinNC is offline   Reply With Quote
Old 07-01-2017, 11:47 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
How hard are you turning the steering wheel? If you are "two-blocking" - hitting the stops hard when turning- that can pull enough energy from the engine to stall it. Further, you should never "two-block" the steering at all, as this drives pump pressures high enough to burst the high pressure hose (with a potentially catastrophic fire). Ask me how I know. Fortunately, it was just a '61 Studebaker Lark VIII convertible. I wouldn't mind having that critter now, if only for the resale value.
~Steven
Simi Valley, CA
Old 07-02-2017, 08:26 AM   #4
Aus69c20
Aus69c20's Avatar
I run my 396 at 600rpm in gear and have no problems with stalling with the a/c
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 07-02-2017, 09:33 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I think 500 is too low of rpm, try 650. I'm sure it wouldn't be too hard to retro a idle solenoid on there though.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-02-2017, 04:49 PM   #6
1972RedNeck
1972RedNeck's Avatar
What's your idle speed in neutral with the A/C off?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
