Old 07-02-2017, 07:21 PM   #1
uncle
Rear Axle ?
Has anyone ever swapped a 12 bolt from 73-81 into 88-98 truck. Any major modifications? Truck is 88 and rear would be from 78. Thanks in advance.
uncle is offline   Reply With Quote
Old 07-03-2017, 08:35 AM   #2
b454rat
Re: Rear Axle ?
Move spring perched and shock mounts. Prolly a conversion joint too.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 07-03-2017, 09:10 AM   #3
Warrens69GMC
Warrens69GMC's Avatar
Re: Rear Axle ?
Since the 10 bolt has a larger pinion shaft, it is stronger than the truck 12 bolt. Plus there are millions of 1988-1999 axles out there for less than it may take you to modify the 12 bolt to work on your truck.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-03-2017, 09:28 AM   #4
uncle
Re: Rear Axle ?
Thanks.
