Old 07-03-2017, 03:43 PM   #1
nheller76
nheller76's Avatar
gear head question
So my friends, here is what i need help with today! I pulled my motor the other day because I had a multitude of leaks and i was tired of trying to find them while it was in the truck. I roll the motor over, pull the pan and find that my rear main cap is chipped on the flex plate side. Not a function problem but it does allow a little oil to seep out, making a mess. Anyone got any ideas about how to fix it without buying a new cap and having the whole thing line board!
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 07-03-2017, 07:36 PM   #2
Jake Wade
Jake Wade's Avatar
Re: gear head question
I don't see where that would cause a leak. You have more than enough gasket surface to seal before it gets to that point. Before reinstalling the oil pan, degrease the main cap gasket surface with brake cleaner and apply a light skim of RTV before laying down the gasket. I prefer the Felpro one piece style.
Jake Wade is offline   Reply With Quote
Old 07-03-2017, 09:41 PM   #3
smpoulin01
smpoulin01's Avatar
Originally Posted by Jake Wade View Post
I don't see where that would cause a leak. You have more than enough gasket to seal before it gets to that point. Before reinstalling the oil pan, degrease the main cap gasket surface with brake cleaner and apply a light skim of RTV before laying down the gasket. I prefer the Felpro one piece style.
X2! Don't believe that will cause a problem.
85 Silverado - 350/700r4
smpoulin01 is offline   Reply With Quote
Old 07-04-2017, 07:29 AM   #4
homemade87
I happen to disagree . It looks like there is some damage in the seal area or close . If it was hit hard enough it could make that seal area out of round enough the seal can not seal proper . Cant see that with the eye . It may have been dropped . Not sure what would have caused that damage .
homemade87 is offline   Reply With Quote
Old 07-04-2017, 09:13 AM   #5
oldpurple
As others have said I'm not sure if that would be causing your leak. Could it just be the rear main seal leaking and making a mess everywhere?
If you want to fix it you could maybe build it up with some JB weld and file it to shape once it has cured, but I don't know if that'd hold. It might be nearly impossible to get it clean enough for epoxy to adhere.
I'd also recommend the fel-pro one piece pan gasket regardless of fix.
oldpurple is offline   Reply With Quote
Old 07-04-2017, 09:16 AM   #6
Tash4
Tash4's Avatar
That looks like where the oil pan gasket rides & rtv should seal it just fine. The rear main seal is on the inside .
Tash4 is offline   Reply With Quote
Old 07-04-2017, 09:34 AM   #7
Desert1957
Desert1957's Avatar
IMO if the Rear Cap was distorted enough to cause a leak at the rear man the bearing on that half of the cap would be showing wear into the copper. If the bearing looks like even wear on both halves, install the new rear seal and try it.
Or reinstall the cap and bolts. Torque to specs. check the cap and bearing with a bore gauge to be sure.
Don't forget about the little trick of offsetting the seal from the cap line.
Rotate the seal 1/4"-3/8" so that the seal split is different then the main cap split.
FYI on the oil pan , ditch the cork and use the one piece "Felpro" oil pan gasket, NEVER had one leak.
Desert
Desert1957 is offline   Reply With Quote
Old 07-04-2017, 11:54 AM   #8
nheller76
nheller76's Avatar
So i figured out what caused it, when i put the motor together i bought a kit that had new bots for my flex plat, when i attempted to use the new bots they bottomed out. I'm wondering if one went far enough to put that divot in it.
I also used the 1 peace felpro gasket but i went through 3 of them because they all leaked. granted i put them in wile the motor was still in the truck and that may have something to do with it.
Old 07-04-2017, 12:34 PM   #9
Desert1957
Desert1957's Avatar
?????? Only use part Felpro #OS 34510T (Shown Below) or Felpro #OS 34500R
I personally have installed over 20 of these over the years on different engines with zero problems, do not let them sell you any other number. This fits 73-86 SBC
Desert
Old 07-04-2017, 10:58 PM   #10
MikeB
MikeB's Avatar
The rear seal from a standard gasket set will probably take care of it with some RTV between seal and rear cap. But a one-piece gasket will do it for sure, and will do a better job of sealing everywhere else, too.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-05-2017, 12:52 AM   #11
gramps77
Attachment 1667174
yeah what he said. Ive had issues with other gaskets. Go to this one, problem always solved.
gramps77 is offline   Reply With Quote
Old 07-06-2017, 08:20 PM   #12
nheller76
nheller76's Avatar
Hear are some more pictures of it, I don't know why but it was leaking like a bad rear main seal. i know the rear main seal is new and put in right.
Old 07-10-2017, 10:01 AM   #13
Pontiac1976
Pontiac1976's Avatar
I bet oil getting under the seal working out. I would get it welded it not cracked or bent, or just a new one. one less thing to worry about.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
