Re: Craigslist sanity check: 4L80e + 5.7L SBC 350
That's a CFI, worse than a TBI, which are actually pretty good.
96 was not a good era for the SBC IMO. you don't want to to try to use that CFI deal, it's a PITA from one end to the other. I see that it does have a distributor in the traditional SBC loction, that helps. Count carefully how many bolts are holding the intake manifold on, it'll be either 8 or 12. if it's 8 it might be an early Vortec, which is a good thing. Look at the back of the block, on the bellhousing flange behind the left head. there should be cast in, not stamped numbers there. post them or a pic of them. |
#2 | |
![]() Join Date: Sep 2016
I'm trying to price and part out what I'll need to convert the engine away from all these electronics. Intake manifold, carburetor, HEI Distributor, etc... I'll post a parts list here to get some feedback so I'm not throwing money down the tube trying to make this engine work. Jegs 20 circuit universal wiring harness. $270: http://www.jegs.com/i/JEGS-Performan...annel=Shopping Intake Manifold, Edelbrock Performer 2116 Vortec: $230 https://www.summitracing.com/parts/edl-2116/ Carburetor Edelbrock 1406 600cfm/electric choke: $334 http://www.summitracing.com/ Hedman 69520 S10 v8 Headers ($180): Hedman 69520 Fuel pump: Holley Red Electric $120 https://www.summitracing.com/parts/h...01-1/overview/ Oil pan... Oil Pump: $23 https://www.summitracing.com/parts/s...-summit-racing Oil Cooler bypass adapter ($25) GM part 19299222 That should be it
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 07-14-2017 at 03:41 PM. |
![]() Join Date: May 2007
