Old 06-19-2017, 09:56 AM   #1
rwdmayhem
helping the old drum brakes
I was curious if adding a power brake booster on my 66 c10 will let the old drum brakes stop the truck a bit better before I get a chance to put the front disk brake kit on the c10. Or is it just going to stop the same with or without the booster?
rwdmayhem is offline   Reply With Quote
Old 06-19-2017, 02:10 PM   #2
chtr65
Re: helping the old drum brakes
I just added an original rebuilt power brake booster to my 65. Much better than without the booster. I like to keep my truck mostly original, so the brake booster was a no brainer for me. I was surprised at the improvement. Plus not the expensive cost of doing all the conversion. I would suggest you go with the booster first. You can always move forward from there.
chtr65 is offline   Reply With Quote
Old 06-19-2017, 03:27 PM   #3
Brad54
Brad54's Avatar
I did it on my '61 Suburban, with the addition of self-adjusters in the hardware.
Much easier to stop.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-19-2017, 09:18 PM   #4
nail pounder
nail pounder's Avatar
X2 on the booster, it makes a huge difference. I have drums on my C20 and it stops great.
nail pounder is offline   Reply With Quote
Old 06-19-2017, 09:44 PM   #5
Johnie
I swapped in a booster and a dual line master on my 64 and am very pleased. It will lock 'em up, which I wouldn't do before.
1964 C10 Long Bed Step Side
Johnie is offline   Reply With Quote
Old 06-19-2017, 09:51 PM   #6
Brad54
Brad54's Avatar
I locked mine up so hard one time that it shattered a front drum.
-Brad
Old 07-04-2017, 08:28 AM   #7
luvbowties
luvbowties's Avatar
Thumbs down Re: helping the old drum brakes
-Brad
Now, that's scary! The shop that probably turned it last cut beyond its limits?
Sam
luvbowties is offline   Reply With Quote
Old 12-05-2017, 02:41 PM   #8
harbinger
Sam
JUST had this happen to me, as well. I didn't inspect the drums before I installed a booster, but tested full lockup and gave the front left an 'inspection hole'. Really glad I had it happen while testing.
To answer the OP, adding a booster makes drum brakes work VERY VERY well.
harbinger is offline   Reply With Quote
Old 12-06-2017, 08:01 AM   #9
PGSigns
PGSigns's Avatar
When I first got the 66 it had drums all the around and needed redone. So I split the brakes, added a power booster and put in all new parts including the brake hoses and new drums. I did take a skim cut on the drums to make sure they were good. First set of shoes were bonded and had a lining come off in the first 1000 miles. Next set were Wagner quick stop rivited shoes and they were much better performing than the others. After the disc conversion I still run that shoe on the back and they do work good. The choice of shoes makes a difference and new brake hoses always seem to improve the feel.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-07-2017, 01:24 PM   #10
yeah_yeah_na
Are you guys running a factory style booter on your drums or is there a better aftermarket one? Any tips on direction for a good supplier would be great.
yeah_yeah_na is offline   Reply With Quote
Old 12-07-2017, 01:47 PM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Many go this route: http://www.67-72chevytrucks.com/vboa...=1#post3257836
Old 12-07-2017, 10:39 PM   #12
oldtractors
-Brad
I did that without the booster. I really don't think a booster is necessary if the brakes are in good shape like they should be. I don't find the pedal effort much worse than a new truck with power brakes.
oldtractors is offline   Reply With Quote
Old 12-08-2017, 12:34 AM   #13
Captainfab
60-66 Nut
If you are running drums front and rear, all you need is a '67-'70 C10 booster and master cylinder plus one of my booster brackets to correctly mount it to your firewall.
Old 12-08-2017, 02:55 AM   #14
sirJim
And they work great!!!
sirJim is offline   Reply With Quote
Old 12-08-2017, 01:43 PM   #15
yeah_yeah_na
Nice and easy, I built a similar thing to mount a booster to my first gen Camaro.
My truck hasn't reached New Zealand yet, its still sitting in LA waiting on the boat. I may be in touch depending on how the brakes feel. I'll be doing a heap of driving over a mountain pass. Brakes with a good feel are a must!
