Old 06-18-2017, 11:26 AM   #126
AnobleL74
Re: Sun Tachometer Retrospective
i love these old sun tachs also, but after owing 2 vintage sun super tach ll that only worked erratically, i tried all the gismos and tricks to fix them but finally i gave up,
problem may be because my chevelle and truck both have HEI.
ended up with a $50 bosch mini tach from advance auto that looks retro like the sun tach and works perfectly.
AnobleL74 is offline   Reply With Quote
Old 06-22-2017, 07:42 AM   #127
Keith Seymore
Keith Seymore's Avatar
Originally Posted by Keith Seymore View Post
My tach finally quit working.
This might not be germaine but I started it back when the weather was cold to let the car run some and the tach went to about 1/2 of what it should be reading.
I replaced the batteries today as described above and that didn't do it.
I'm going to make sure the "new" batteries are not dead and after that I'm out of ideas.
Any suggestions?
Thanks in advance -
K
Fixed it.
I checked the removed batteries and they were still at 1.36 volts.
I cleaned up one of the contacts, which had some corrosion on it, and put them back in with some dielectric grease. I'm back in business.
This September that tach will have been in use for 53 years!
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-04-2017, 09:22 AM   #128
rideblue00
rideblue00's Avatar
Really nice write-up!
rideblue00 is offline   Reply With Quote
