Old 07-04-2017, 09:19 PM   #1
Nuckingfuts
Ride height change when adding a leaf spring?
Our 73' shortbox currently has a DJM suspension kit that includes 3" drop spindles, 2" drop coil springs up front, flip kit in rear (including shock extenders), and new twin tube shocks all around. The overall truck ride height is about 3/4" lower in the rear, resulting in a stance that looks slightly 'sagging' in the rear. I'd like to level the truck out by raising the rear with either a) lifting shackles which give about 1" rise or b) adding a leaf spring to the pack. I'm leaning towards adding a leaf to both stiffen up the rear and hopefully raise the ride height, only problem is I'm not sure how much static ride height I would gain from it.
Any input or thoughts on this one?
Nuckingfuts is offline   Reply With Quote
Old 07-04-2017, 09:51 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Ride height change when adding a leaf spring?
Why not lightly trim the front springs to bring the front down?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-04-2017, 10:50 PM   #3
MikeB
MikeB's Avatar
Sometimes just adding a leaf doesn't change the static ride height, but only reduces the amount of sag under load. However, if your truck currently has a 52" 4-leaf pack, I've read where a new 5-leaf pack (Dayton 22613) will raise it about 1". You might want to check with Dayton, TruckSpring.com, or SDTruckSprings.com.
Obviously, a shackle that raises the truck 1" at the axle (2" down on the shackle) would be less expensive.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-05-2017, 11:08 AM   #4
Nuckingfuts
I would but I'm already at a 5" drop which leaves only about 2" of travel before the tire rubs the fender well (which has happened a couple of times) so I'd have to stiffen up the front with that route. Not sure if heavier coil springs are an option out there?? Thoughts?
Changing out the shackle seems the simplest route at this point but I lose some of my lowered stance.
Old 07-05-2017, 02:51 PM   #5
Nuckingfuts
I'm just spitballing here but wondering if I took a set of C20 coil springs, which I would assume have heavier spring rates, and chopped them to make a 3" drop (remember my current springs are 2" drop). This would both stiffen the front and level out the stance. Just not sure if they would be stiff enough to control 1"+ of travel. Thoughts?
Old 07-05-2017, 03:06 PM   #6
SkinnyG
SkinnyG's Avatar
I never ran lowering springs in my C10 because it has been my experience on other vehicles that most lowering springs are too low and too soft.
I am running BellTech spindles and a flip, and I cut a coil (or was it a coil and a half??) off the stock springs, but it was too soft and the tires rubbed the underside of the fenders.
I bought some Moog #6454 1-ton springs, and initially cut a coil, but kept cutting 2" off the end until I got the ride height I wanted. WAY better ride, and no tire rub at all (that I notice).
Old 07-05-2017, 03:13 PM   #7
Nuckingfuts
That's good feedback!
Since you have some experience comparing the two let me ask you this, could you get away with taking off 2.5-3" with that Moog 1T spring?
Old 07-05-2017, 09:42 PM   #8
SkinnyG
SkinnyG's Avatar
With 235/70R15 tires up front (28" tall), I have about 26" from ground to the fender edge, with 3" BellTech spindles and heaven-knows-how-much I cut off the 1-Ton springs.
I am running full-height factory bumpstops as well.
I think the rear fender edges are a tick higher.
