Old 06-28-2017, 09:21 PM   #1
jackson
fan
49 ad with stock 283 aluminum radiator. can I run an engine driven fan
with offset fan shroud. [fan is low on radiator] I have room but my buddy
said an offset fan shroud might not pull enough air from the top of the rad. I think it will work, what do you guys think
jackson is offline   Reply With Quote
Old 06-29-2017, 08:39 AM   #2
jackson
Re: fan
so has anyone run a v8 with engine driven fan in an ad
Old 06-30-2017, 12:06 PM   #3
jackson
Re: fan
oh well
Old 06-30-2017, 06:21 PM   #4
mr48chev
mr48chev's Avatar
Re: fan
I did for years with no shroud. First with the stock core and then with a 2-1/2 ton truck core in my tanks. I never had a cooling problem with that setup until the radiator died of old age and probably vibration as I had left some of the support off in the subframe swap.
I'm thinking that the stock 1-1/2 ton shroud I have out here isn't centered on the core.
I did without problems. Stock radiator with a 283 and I am thinking a fiberglass flex fan. I went though a lot of those as they were always cracking blades.
A shroud with an offset hole should work ok if it is designed so the air can flow to the fan. This is the stock shroud on a 1-1/2 ton. Note that there is a pretty decent space between the shroud and the core. At least 2-1/2 inches of space for the air to move in the corners.
My ongoing truck projects:
Old 06-30-2017, 09:52 PM   #5
jackson
Re: fan
building one almost identical to that . thanks for posting
Old 07-04-2017, 09:43 PM   #6
57chevyman
57chevyman's Avatar
Re: fan
i have a v8 with engine driven fan, no shroud, no problems
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 07-04-2017, 10:18 PM   #7
tmoble
Re: fan
hot water is at the top. best place to cool it. I've got a 54 with MII clip and SBC under construction right now, when I saw how low the fan was I ordered up a 16" electric. installed but not driven yet. It has A/C and it's like 108 outside so it won't take long to find out.
tmoble is offline   Reply With Quote
