Old 02-04-2017, 02:29 PM   #1
cst69
Hollywood
cst69's Avatar
Kilroy - a fun loving ratty build
OK, bought a 1969 C-30 flat bed 350v8 4 speed. After driving "yes DRIVING" it home over 60 miles home it didn't take long to know it must have the lowest gears offered in the rear end. After stopping for gas and water (it was spewing out the radiator from riding 65 down the highway) it did great as long as I stayed on the business route below 55 mph. Upon initial inspection the mechanicals are great but the cab is a basket case. My brother is on board with me in making something unique out of it. I want something fun to take to the car shows which at least makes people stop and say "whaattt". I don't want anything perfect, just kinda a figment of my insane imagination!. Let's start at the beginning with the pics upon getting it home then we can go from there.
1968 cSSt shortbed
1971 custom deluxe shortbed frame off
1991 caddilac escalade ST shortbed
1992 chevy ext. cab Project: leftovers
2003 Silverado ext. cab shortbed (my dad's truck R.I.P.)
1969 trans am clone, pro tour
1985 Yamaha Vmax, custom
1993 Yamaha Vmax, showbike
1969 Sears Suburban SS12 lawn tractor
cst69 is offline   Reply With Quote
Old 02-04-2017, 02:33 PM   #2
cst69
Hollywood
cst69's Avatar
Re: Kilroy - a fun loving ratty build
Ok, first thing to go was the rotten wood flatbed. It looks pretty mean without the bed!
1968 cSSt shortbed
Old 02-04-2017, 04:25 PM   #3
cst69
Hollywood
cst69's Avatar
Current direction with ole Kilroy!
Established a goal of having it ready for "Run 2 the sun" car show in Myrtle Beach on March 16th, 2017. Will I have everything done by then? Hell no! not enough time! I do have some goals and it will run & drive and be presentable or I will take my 71 instead (not a bad back up plan).
Kilroy - Late 60's/early 70's nostalgia build with Rat/Hot Rod influence.
Suspension:
Rear end swap to later model "wide" 14 bolt dually rear with friendlier rear gear ratios. Flip kit of rear axle with 2" lowering blocks to get that fat rear down 8", also removing leafs to aid in drop. Custom coil over shocks, helper air bags and old school slapper bars for nostalgia.
Front end: Disc brake conversion w/ 2 1/2" drop spindles and 3" drop springs with a coil cut off of those to get slight rake on front or Air bags? drop shocks.
Wheels and tires: 20" x 7.5 KMC machete front dually offset wheels w/ 245-45-20 street tires, 20" x 12" single wheel TIS 538 (matching design deep lip) wheels with 315-35-20 street tires. Finish is black outer lip with satin gray or gold wheel face.
Interior: Beige paint on metal, tan seat and dash pad, charcoal gray door panels, gauge cluster & glove box, shotgun shifter handle with rat rod type accessories thru out. Wood floor board.
Body: patch & bodywork, scuff and paint exterior Charcoal Gray Metallic Hot Rod Flatz & Hot Rod Flatz Gold scallops. Custom front push bar and all trim & grill Murdered out Satin Black. Bed is 1968 stepside long bed box with the fenders removed, don't think I will run any rear fenders but we will see how it goes. blacked out lenses and a few surprises along the way. Custom wood bed floor raised inside bed, beer keg style gas tank, custom satin black headache rack & possible stainless steel rear wing??
Mechanical: 383 sbc, double hump heads with 280 cam. Gilmer belt alternator belt and brackets, vintage Eldenbrock finned black valve covers, vintage tunnel ram with 4" extensions and scuffed up to look old and stick thru the hood with dual 450 holley's and twin shotgun air cleaner in scuffed black finish. Petronix distributer with yellow spark plug wires and headmen full length headers. 700 r 4 overdrive transmission with 2200 stall converter.
Rough Sketch attached.
1968 cSSt shortbed
Old 02-04-2017, 04:35 PM   #4
cst69
Hollywood
cst69's Avatar
Swapped 80's rear end swap mocked up, awaiting suspension parts front & rear.
1968 cSSt shortbed
Old 02-05-2017, 12:42 AM   #5
cst69
Hollywood
cst69's Avatar
rough sketch...
1968 cSSt shortbed
Old 02-05-2017, 06:59 AM   #6
AKC
AKC's Avatar
Cool! Another C30!
Good luck with the build...
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline   Reply With Quote
Old 02-05-2017, 07:31 AM   #7
GR8-68
GR8-68's Avatar
In for the ride here, this is going to be sweet, I was just offered a 70 c30 for 500.00 complete May look into it. Are you using a single wider tire on the back like they have started using on the semi trucks ?
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-05-2017, 10:02 AM   #8
cst69
Hollywood
cst69's Avatar
Thanks and yes, super single in the back although it is only a 20" x 12" wheel in the rear. I have really had a hard time choosing wheels and tires for this rig. Most people are going with the super single semi wheels, either 22.5 x 14 with the large 405 semi tires using wheel adapters to fit a 8 bolt or buying custom rims from a few places. I wanted something that was different and did not break the bank. I plan on getting these on order this week.
1968 cSSt shortbed
Old 02-07-2017, 12:30 AM   #9
cst69
Hollywood
cst69's Avatar
Stripped the interior this weekend, made some crude floor pan patches, sprayed all the interior metal in almond, dash pad and seat are camel tan color and door panels, cluster and glove box are charcoal to match the exterior. Started putting everything back in last night but ran out of time. Started some minor bodywork on the exterior. My front disc brake upgrade plus lowering spindles should be here mid week, and hopefully the flip kit for the back will be here Friday so we can get this thing rolling again...and low! Brought my field find step side bed over to my brothers shop, its going to need some, no a lot of work! Picture attached. I will try to get some interior pics soon!
1968 cSSt shortbed
Old 02-07-2017, 06:41 AM   #10
GR8-68
GR8-68's Avatar
Sounds like it is moving along well, looking forward to seeing the pics
Larry
"Project 68"
paypal.me/ldgrant
Old 02-07-2017, 08:16 AM   #11
flashed
Just seeing this one ,Im in for the rest of the trip.
flashed is offline   Reply With Quote
Old 02-20-2017, 02:30 PM   #12
cst69
Hollywood
cst69's Avatar
update on work...after some back and forth with delivery lead times I made a 73 up kit work for my rear end. of course between using an 1982 model 14 bolt dually rear from a friend, a 73-87 flip kit installed on a 69 dually narrow rear axle frame nothing lined up or was especially easy due to the leaf spring mounting pad was in different locations. We made it work, now if i could get the correct front disc brakes for my dually sent to me instead of a standard C30 I could finish my suspension! Got the interior painted, just need to finish the floor and add my accessories. Started some body work also. Going to wait until I get the front suspension slammed to know if I am going 2" lower with the back? It's going to be low as the back is already 7" drop and the front should be around 6 1/2"-7" drop.
1968 cSSt shortbed
Old 02-20-2017, 02:56 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
That's a long list for "run to the sun". It's in like 3 weeks? Pretty cool looking truck as is.
Quite a few members of the Upstate GM truck club will be there. I can only go on Saturday, so I'm waiting to make sure it's going to be a nice sunny day.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-20-2017, 03:55 PM   #14
cst69
Hollywood
cst69's Avatar
67CHEVYRED, yes it is. I was on track with no time to spare! However, the suspension parts I needed that were not correct has doomed my completion date. Already knew i wouldn't have my engine or drive train done but I was hoping to have most of it done as far as suspension, interior and exterior. Oh well, life is full of disappointment. If I can get it together enough I might bring it anyway, one thing is for sure I am going to the show! Already booked the room and can't wait to see everything! C you guys there I hope!
1968 cSSt shortbed
Old 02-20-2017, 06:12 PM   #15
RDrancher
RDrancher's Avatar
In to watch where this is going.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 02-21-2017, 12:53 AM   #16
cst69
Hollywood
cst69's Avatar
new sketch of build direction except light areas are charcoal metallix satin & dark areas are gold matallix satin I think.
1968 cSSt shortbed
Old 02-21-2017, 08:12 AM   #17
flashed
Im liken it .
Old 07-06-2017, 02:26 PM   #18
cst69
Hollywood
cst69's Avatar
Stardate 8/2017: after much shenanigans with my suspension vendor (them advertising a drop spindle & disc brake conversion for my 69 C-30 dually) I have used what they gave me and then modified my suspension in order to mock up my ride height. Went down 7" drop in front & 8.5" in rear (modified flip kit) static drop. I still have a long way to go as the rotors on the front will not clear the valve stems in front with the 16" rims but the 20's I am installing should fix that. Just goes to show just cause it's advertised doesn't mean it fits...alas, that's why it's called custom! Anyway, I am still waiting on a few parts before I get back on it because we have started a restoration on my brothers 65 C-10 stake bed. I might slip some pics in on that project also. Anyway, wanted to slip in a picture of the build as to date.
1968 cSSt shortbed
Old 07-06-2017, 02:36 PM   #19
flashed
I would look at pics of the 65 C-10 stake .
