Removing rear pinion yolk nut...broke my breaker bar?
At the bone yard I was trying to remove that 1 5/16" nut off the rear differential yolk with a 6 point impact socket and my 1/2 break bar.
Laying on the ground with my feet against the p/s leaf springs of this 86 c3500 dually, I ended up breaking my American made breaker bar. My eyes are not the best but is that factory nut slightly crushed so it will not come loose as are other factory nuts? I cannot even believe how tight that was, I thought I was going to rotate the truck I was pulling so hard. So what's next? I see guys on Youtube using impact guns but does this not cause the pinion gear and ring gear to chatter on each other and cause surface damage to both? I doubt an impact gun could get this nut off anyway. Any help would be nice....thanks ahead of time. |
#2 | |
Re: Removing rear pinion yolk nut...broke my breaker bar?
One time I used a floor jack against a breaker bar to loosen a pinion nut i'm a pretty hefty guy but even I couldn't loosen it. Or you need something like this https://store.snapon.com/1-Drive-Hea...h-P888527.aspx
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
they are on real tight. had to use a winch line on a breaker bar one time on a Jeep trying to change the pinion flange on it. impact don't hurt the gears.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
