Re: 4.8 carb tuning help
I'm not familiar with the Summit carbs, but I'll help the best I can.
A few questions and suggestions first. 1: Your timing seems kind of low. My cam is slightly more aggressive, but most carbed applications I've seen use more timing. I had my timing set a 38* all in by 1200 rpm and held flat all the way past the rev limit. Is there any particular reason to back the timing back off after 4400rpm? 2: What's your thermostat temperature, and what's the typical operating coolant temp? 3: Vacuum or mechanical secondaries? 4: As geezer mentioned, power valve and idle vacuum numbers are important. We can move forward once we have this info.
#2 | |
