04-12-2004, 03:27 PM | #1 |
Removing turn signal switch
I recently picked up an auto steering column and I'm in the process of cleaning it up. I was wanting to remove the turn signal switch assembly, but the hazard switch is making it just a bit difficult...
From what I can tell you can't remove the hazard switch, so how do you get it out (the assembly) without breaking it (hazard switch)? thanks! |
04-12-2004, 03:36 PM | #2 |
67-72 Addict!
Disconnect battery first!. Then push in button to gain clearance. It's tight but will wiggle out with it pushed in.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-12-2004, 03:46 PM | #3 |
On my 72 tilt column, the hazard switch knob unscrews from the turn signal assembly just like it was a regular screw.
Paul 72 Cheyenne Super Custom Camper greenaz@hotmail.com |
04-12-2004, 04:12 PM | #4 |
I'll give a try one more time!
thanks. |
