Old 07-08-2017, 04:42 PM   #1
dcfd470
How do you attach upper trim?
How do you attach the upper trim on a short bed? I haven't started it yet but I don't see how you can get the nuts on the back of the trim clips. No access and the bed has never ben drilled for the. Thanks Bill
dcfd470 is offline   Reply With Quote
Old 07-08-2017, 05:32 PM   #2
ray_mcavoy
Re: How do you attach upper trim?
I believe 69 & 70 used spring-metal snap-in clips to attach the upper bedside molding.
Sometime around 71 or so they changed to plastic clips stuck to the body with 3M (or similar) adhesive. I think they still used the snap-in metal clips at the very front & back ends of the molding though.
ray_mcavoy is online now   Reply With Quote
Old 07-08-2017, 05:46 PM   #3
dcfd470
Thanks I did order my new molding and it comes with 3m adhesive strips. I guess I will wait until get them to check it out.
Old 07-08-2017, 06:20 PM   #4
rockyrivermark
Heads up the LMC upper trim with adhesive clips doesn't stick. Mine started to fall off first 80 degree day.
Typical of everything I bought from LMC. garbage.
If it's not 3m VHB tape change it over before sticking.
rockyrivermark is offline   Reply With Quote
Old 07-08-2017, 06:34 PM   #5
dcfd470
I'll have to check I think I got them from Brothers or Classic.
Old 07-08-2017, 06:36 PM   #6
dcfd470
Oh I was wrong I did order them from LMC. I got doors from Goodmark and some other things from Classic.
How are they other than the adhesive? I can put 3M double side tape on them.
Old 07-08-2017, 07:02 PM   #7
Chevyland
Chevyland's Avatar
Here you go
These are the clips and stickers
From left to right
Lmc clip
Classic or maybe brothers clip
Lmc adhesive
Broken original clip
I never use the adehesive
It doesn't stick good and it holds the trim to far from body
Originally
Long beds had 4clips.
2 front 2 rear and 10 or 12 stickers
Short beds had 1 clip front and back and 8 stickers
Anytime I'm putting upper trim on
I string line between front and back hole
And drill 6 to 8 more holes matching original size
Equidistant between originals
And use ALL clips(just order more)
This guarantee's your trim will stay on
Even on original trucks where the stickers have failed
Usually the clips are still holding strong
Red truck is shortbed,first pic still shows broken original clip in hole
Ochre truck is longbed
Chevyland is offline   Reply With Quote
Old 07-08-2017, 07:03 PM   #8
rockyrivermark
I ended up pulling all my bed trim off.
Cut off the old tape and used a quality 3m tape.
So far no problems.
Clean bed of all wax along trim line first.
The trim itself is decent.
FYI for others. The lower body trim was LMC was a pain. The clips where too short and would spin when tightening the nut. The clip is supposed to be a bit longer so it cannot spin but rather lock in.
I retuned most of the items I got from LMC. it's just crap.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
Old 07-08-2017, 07:09 PM   #9
dcfd470
Thanks for the info I may buy new clips. I think I got it now most of the clips on the bed just push into place. The end ones have nuts.
Old 07-08-2017, 07:11 PM   #10
dcfd470
They all push in....
Old 07-08-2017, 07:47 PM   #11
rockyrivermark
I checked my 3m tape and was a touch loose.
Literally just drilled and installed the push in clips since I had them.
Use a little silicone caulk around the holes to keep from rusting. Water holds under that trim.
Mark
Old 07-08-2017, 07:55 PM   #12
notsolo
notsolo's Avatar
Originally Posted by Chevyland View Post
Here you go
From left to right
Lmc clip
Lmc adhesive
Originally
Thanks Eric for the tutorial on the different clips, saves me asking about this later. Have you made or found a tool to remove the OEM clips, or just 2 thin putty knives.? Does any body sell a box of 25 clips?
notsolo is offline   Reply With Quote
Old 07-08-2017, 08:00 PM   #13
Chevyland
Chevyland's Avatar
Pliers, hammer. Air chisel🤷*♂️
Whatever works
I think most all sell individually
Try and get the black ones.
I like those better than lmc ones
Old 07-09-2017, 12:35 AM   #14
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
For what it's worth, see post #1 at the following link. It lists what came with my NOS upper, lower & rears moldings. Includes some other info. that may make life easier. It's for a short bed. Can't say when the parts were manufactured.
http://67-72chevytrucks.com/vboard/s...d.php?t=735842
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-11-2017, 10:05 PM   #15
Chevyland
Chevyland's Avatar
Pics for randy500
These are measurements of the stock holes
Front and back upper trim
On a Shortbed
In the first pic the lower tape measure IS lined up with body crease
(Even though it doesn't look like it)
In the last pic. The tape measure is hooked on the curve of the metal
Inside cavity for marker. NOT where metal ends
