Old 07-08-2017, 09:56 PM   #1
davischevy
davischevy's Avatar
Re: Can a dimmer switch be bad, but still work?
The first thing I would check is the plug in the back of the cluster tight. It sounds like a ground problem. The printed circuit may be shot. These electrical gremlins can be tricky.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 07-08-2017, 09:58 PM   #2
davischevy
davischevy's Avatar
Usually the dimmer will make the headlights go dark if it is bad.
other Larry
Old 07-08-2017, 10:35 PM   #3
custom10nut
custom10nut's Avatar
The printed circuit is new. I'm going to take the dash apart tomorrow to ground the other screw, and I'll check the plug then.
I have to try to fix my tach too.
custom10nut is offline   Reply With Quote
