12-03-2015, 12:27 AM | #1 |
Higher Quality Turn Signal Switch
Working on a 1963 C60. The original turn signal switch was bad so I ordered a new one through Orange County Truck Parts (same parts as LMC, just cheaper). It worked great for about a month and then the self canceling cam broke. Now it has started to randomly make both rear lights flash.
Any where I can get a high quality turn signal switch? Thanks |
12-03-2015, 01:14 AM | #2 |
Re: Higher Quality Turn Signal Switch
Classic industries! Buy the uber expensive OE type. It's worth it!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
12-03-2015, 12:47 PM | #3 |
Got a link? I see 1955 - 1962 and 1964 - 2002, but no '63. And '63 was a one-off switch.
12-03-2015, 07:00 PM | #4 |
Chevy addict
I use Classic Truck Parts better switch, been lasting in some of my regularly used truck for years. http://www.classicparts.com/Switches/products/206/
12-03-2015, 07:18 PM | #5 | |
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
12-03-2015, 10:25 PM | #6 |
1964-66 turn signal canceling cam (not entire turn signal switch) is:
Dorman part # 49308 $15 Amazon, NAPA etc. |
07-09-2017, 02:26 PM | #7 |
The switch at Classic Parts for my 66 looks exactly the same as the one I got from the Truck and Car Shop. Worked fine for a bit then the contacts bent and started to flash constantly. I've taken apart and re-bent the contacts only to have them work inconsistently. The plastic parts on this are fine but the contacts are really cheap.
Does anyone have a real good quality turn signal switch that works? Thank you. Dan |
07-09-2017, 02:30 PM | #8 |
See my lost above. #2.
I had the same problems with the aftermarket parts. Buy a GM version.
07-09-2017, 02:40 PM | #9 |
Thank you.
Would the Autowire one that is said to be "GM tooling" be a good one https://www.summitracing.com/parts/a...s/applications or the AC Delco one http://www.rockauto.com/en/moreinfo....1321850&jsn=11 Any other links appreciated. Dan |
07-09-2017, 07:18 PM | #10 |
From that list it looks like the expensive switch for a 63 is 53-507A. I think a C60 deserves a good one.
07-10-2017, 12:57 AM | #11 | |
Not to hijack. Well kinda hijacking. Good to see ya here Jason. Hope all's well!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-10-2017, 06:44 AM | #12 |
I bought a life time warranty 1 at O'reillys 9 years ago Borg Warner I do believe
07-10-2017, 09:29 AM | #13 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
