#18 |
Re: 4l80e No Overdrive
Truck is back on the road...
Replaced the transmission with a good unit that I had in one of my other trucks. Immediately thru a code and was stuck in 2nd and 3rd again. After I calmed down, I started checking the wiring. I didn't see anything out of order at the transmission. So I went to the ECM to start tracing wires. What I found was that the large connector at the ECM was not fully seated properly. The only condition that it caused was the transmission problem I was experiencing. No other issues. Transmission shifts beautifully and I couldn't be happier with the swap. |
| Bookmarks |
