Old 07-12-2017, 12:00 AM   #1
mike in mo
Suburban gas tank in c30 crew cab
Been searching reading digging all night im wanting to put a suburban tank on my 80 chevy c30 crew cab most all the post I find are half tons or shortness any one do a 1 ton long bed? Whats got to move I got factory rear sway bar and a class 5 hitch that all got to be back there. Not worried about the fill neck it can be built in the flatbed someplace.
mike in mo is offline   Reply With Quote
Old 07-12-2017, 12:38 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Suburban gas tank in c30 crew cab
Should be pretty easy with the long bed. Work from the rear cross member forward. I don't think you will run into anything major. I had to clearance my tank for the passenger side shock, but I have a short bed K30.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
