Moderator
![]() Join Date: Jun 2017
Re: Longbed mounting hole placement
Check your IM and email...I sent you the measurements off of my truck...
![]() Join Date: Jun 2010
I put my boards in today. I definitely dont think you want my measurements, My boards seem too narrow, so the gaps between them are too wide.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Moderator
Suggest you check out
http://www.gmcpauls.com/47-72_BedWood_Info.htm Make sure your boards are correct overall width...there are many different widths depending on what bedside or box you have. I usually end up with about 1/2" - 5/8" between the boards where they sit on the cross rails... ![]() ![]() ![]() |
![]() Join Date: Jun 2009
What dimension did you cut your boards at ? There is supposed to be a good amount of play for movement as the wood grows and contracts
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
7 7/16 wide for the widest ones. I think part of my problem is that I mounted the second board (the one that is cut out around the wheel well) too close to the bedside, so there is a large gap to the 3rd board. I can probably take the bolts out and move the board inward a little bit to tighten things up.
Moderator
I am attaching a pic of the bed board mounting showing how the wear strips are embedded into the bed wood...thanks to GMCpauls for the image...
There needs to be approx 1/2" - 5/8" inch gap between the two boards where the bolt goes thru, to allow for expansion of the wood due to moisture and weather etc. The bolt should be 1/4"...so you should have approx 1/8" to 3/16" either side of the bolt shaft. I always find it easier to not bolt down the 3rd board in from outer edge to the wheel covers until all of the bed planks are in place. |
