Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 05-09-2017, 11:12 AM   #176
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
back up
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 05-10-2017, 07:41 PM   #177
duke_lbz
duke_lbz's Avatar
Need a price for radiator for 67 c10 ls6 4l80 with trans cooler and electric fans please
07 GMC Sierra 2500 compound turbo' duramax
99 GMC Yukon solid axle swapped
67 Chevy c10 small window swb stepside supercharged ls6
70 Chevy c10 suburban
72 K5 Blazer 4wd
duke_lbz is offline
Old 05-11-2017, 10:02 AM   #178
SparkyRnD
SparkyRnD's Avatar
The radiator is $425 after discount. For the fans, what hp is your engine making? We have 3 levels of fan kits, and here are the prices after discount:
standard kit (dual 12's): $220, good to around 425hp
upgraded kit (single 16 HD or single dual-speed 17 HD): $320, good to around 550-600hp
extreme duty kit (dual extreme duty 12" fans): $430, we have these on vehicles with upwards of 1,000hp
Shipping to AL is $50
Old 05-11-2017, 10:24 AM   #179
duke_lbz
duke_lbz's Avatar
The engine is supercharged don't know if that matters or not. But it's currently putting a little over 500 to the wheels
72 K5 Blazer 4wd
duke_lbz is offline
Old 05-11-2017, 04:33 PM   #180
SparkyRnD
SparkyRnD's Avatar
That does make a difference. That means you are probably in the 600-620hp range. I would go with the upgraded unit at a minimum, and would consider the extreme duty (that's what I run on one of my LS applications that will eventually be boosted).
Old 05-22-2017, 05:48 PM   #181
SparkyRnD
SparkyRnD's Avatar
back up
Old 06-09-2017, 10:11 AM   #182
SparkyRnD
SparkyRnD's Avatar
up top again
Old 06-11-2017, 12:13 AM   #183
Jason7121
Jason7121's Avatar
Nice looking radiatior. I need a price on 1 for a 71 c10 I have 4 row mounts. I also have the Lq4 ls truck motor. Don't need steam port or heater hose outlets but do need a trans cooler that will work with the factory steel lines. Also want dual good fans with shroud. Thanks my name is Jason.
Jason7121 is offline
Old 06-11-2017, 08:24 PM   #184
SparkyRnD
SparkyRnD's Avatar
The Forum member discounted price is $425 for the radiator, and for the fans I need to know what kind of power you are making in order to make a recommendation
Old 06-19-2017, 01:28 PM   #185
dieseltech619
How do i order? I went to your site and i saw i can buy via PayPal but doesn't give as option for the forum discount or to specify ls swap and port location ... also what is your current lead time?
dieseltech619 is offline
Old 06-19-2017, 01:32 PM   #186
Jason7121
Jason7121's Avatar
Power is 400 hp on mine with ls motor
Old 06-27-2017, 10:36 AM   #187
SparkyRnD
SparkyRnD's Avatar
I can send a paypal payment request via email. Just PM me which radiator you need, engine / trans info, hp level and if you want a fan & shroud kit, controller with relay and / or an overflow, along with your zip code and email address and I'll put together the invoice and email it over (it'll include the discount). For those that order online, if you email or PM me just after the order is placed (but before it ships out), we can adjust the order to reflect the discount and either refund that, or deduct it from the shipping.
Ok, that will use our standard 12's unless you are in a very hot location (southern USA, etc). Those are $220 with forum discount. let me know if you'd like to order.
Old 07-10-2017, 11:22 PM   #188
SparkyRnD
SparkyRnD's Avatar
Thanks for the orders!
Old 07-13-2017, 06:13 PM   #189
cdog73
So what is your actual lead time if I were to order a radiator from you say this coming Monday. And also, can I get a quote for an LS swap radiator, no fans or shrouds, no trans/oil cooler shipped to 46755. Thanks, and I will be in touch soon.
cdog73 is offline
Old 07-13-2017, 06:19 PM   #190
SparkyRnD
SparkyRnD's Avatar
we are about 3 weeks out from date of payment at the moment, possibly sooner. The discounted price is $425, and shipping is $60 to that zip.
Old 07-13-2017, 06:38 PM   #191
cdog73
Thanks man. Not sure I wanna drop 5 bills on a radiator but if I change my mind I will be in touch.
cdog73 is offline
Old 07-13-2017, 11:08 PM   #192
SparkyRnD
SparkyRnD's Avatar
No problem, thanks
Old 07-16-2017, 01:01 PM   #193
NC_John
NC_John's Avatar
Your fabricated valve covers for LS engines - do they have a provision for oil fill?
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline
Old 07-23-2017, 05:59 PM   #194
Blazerowner
Blazerowner's Avatar
I'm considering one of your radiators but the one year warranty throws me? I barely drive my blazer and don't want to spend close to a grand to only have it spring a leak in a few years. I was looking at Other options and some offer a lifetime warranty against manufacturers defects. I have heard of people going through 3 or 4 radiators that leaked (not yours).
Kirk
72 Blazer CST 4wd highlander
Blazerowner is online now
Old 07-25-2017, 01:36 PM   #195
SparkyRnD
SparkyRnD's Avatar
We can set them up that way if you'd like.
We've always offered a 1 year warranty, as anything that has to do with a manufacturing defect will present itself within that time. Most of the lifetime warranty units are import junk that will continuously leak / get replaced.
Old 07-25-2017, 03:24 PM   #196
Blazerowner
Fair enough but my concern is I drive about 2-3000 miles a year if that. Would you stand behind it after the warranty if a weld failed or some other defect presented itself? I'm looking at entropy and they are made state side with a lifetime warranty.
What do you recommend for an ls3 swap in a 72 blazer? At most 500-600 hp.
Kirk
Old 07-25-2017, 04:16 PM   #197
SparkyRnD
SparkyRnD's Avatar
Our current policy is 1 year against manufacturing defects. We usually work with our customers, and rarely have any warranty claims. We get a lot of former Entropy / Champion customers.
On that set up, I would go with our 17" dual speed HD fan which is good to around 550hp. Above that and in warm temps, I recommend our Extreme Duty dual spal 12's which are good to just shy of 1k hp.
Old 07-27-2017, 09:22 PM   #198
NC_John
NC_John's Avatar
PM sent....
1970 C-10 LWB "Blu"
NC_John is offline
Old 08-15-2017, 08:47 AM   #199
SparkyRnD
SparkyRnD's Avatar
bringing up again!
Old 08-15-2017, 11:23 AM   #200
Steve Cole
Hey Sparky,
You said your LS swap radiators have NPT fittings for the transmission cooler lines. Is there anyway to get the quick disconnect O ring fittings instead, so the factory hard lines can be used with your radiator?
Thanks.
Steve Cole is offline
Closed Thread
