![]() Join Date: Jun 2009
Re: Longbed mounting hole placement
What dimension did you cut your boards at ? There is supposed to be a good amount of play for movement as the wood grows and contracts
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
![]() Join Date: Jun 2010
7 7/16 wide for the widest ones. I think part of my problem is that I mounted the second board (the one that is cut out around the wheel well) too close to the bedside, so there is a large gap to the 3rd board. I can probably take the bolts out and move the board inward a little bit to tighten things up.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Moderator
![]() Join Date: Jun 2017
I am attaching a pic of the bed board mounting showing how the wear strips are embedded into the bed wood...thanks to GMCpauls for the image...
There needs to be approx 1/2" - 5/8" inch gap between the two boards where the bolt goes thru, to allow for expansion of the wood due to moisture and weather etc. The bolt should be 1/4"...so you should have approx 1/8" to 3/16" either side of the bolt shaft. I always find it easier to not bolt down the 3rd board in from outer edge to the wheel covers until all of the bed planks are in place. |
