Closed Thread
Old 07-11-2017, 03:56 PM   #5576
JG358
JG358's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Metaldoc View Post
It's like I've seen that before.LOL
LOL, for some reason I don't think mine will buff out as nice. Going back up to haul it home in November. Hoping to have it running by Christmas.
What drop do you have on yours?
JG358 is offline
Old 07-11-2017, 09:41 PM   #5577
Metaldoc
Metaldoc's Avatar
That is original never buffed and I have 5 and 7 drop static ride. Mine has taken about me about 3 years and about 1500 hours now but I love It. Hard work and dedication gets it done.
Good luck on the build, Derek
Metaldoc is offline
Old 07-15-2017, 08:11 AM   #5578
SoCoC10
SoCoC10's Avatar
Got painted yesterday morning. Getting color sanded, cut and buffed, then assembled early next week.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 07-15-2017, 08:42 AM   #5579
rustytruck50
rustytruck50's Avatar
'68 Chevy....looks great...gonna need to see more pics of this one!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 07-15-2017, 06:06 PM   #5580
ohboy321
ohboy321's Avatar
I have been busy the last few days. Finished installing my new front springs. Someone had used blocks in the front to raise it 1.5 inches so I needed to get rid of them. Went with Tuff Country EZ-Ride 2”lift. Changed the fluid in my front differential and painted the cover. Did a driveway alignment using a method I read about in Skinned Knuckles. I had tried doing one last year with string, but it obviously didn’t work out so well because I found that toe was out 1/2 inch!!
I am a long way from replacing sheet metal so I riveted in a patch to cover a hole in my floor to get it ready for state inspection. Also painted my front emblem. I hope to get it inspected next week!
ohboy321 is offline
Old 07-15-2017, 06:41 PM   #5581
JG358
JG358's Avatar
Nothing exciting, just filed title paperwork.
Jake
JG358 is offline
Old 07-15-2017, 07:54 PM   #5582
Nh4clo4
Nh4clo4's Avatar
Looked at it, thinking I should do something��
Nh4clo4 is offline
Old 07-15-2017, 10:48 PM   #5583
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Pulled the exhaust and probably won't use any of it. Though I'm hoping for a rear hanger, just in case
Looks great SoCoC10
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 07-15-2017, 11:15 PM   #5584
FL71C10
Put in new bed wood. I used pressure treated southern yellow pine boards. I had a hard time finding boards that were wide enough. Had to by 1 x 10 x 16' boards from a dock supply place. Painted both sides with POR15 and finished the tops with Rustoleum Hunter Green. I used the dimensions from the GMC Paul website, and the boards don't seem wide enough. the gaps between them are very wide. Looks good though, definitely better than it was before. I used gloss paint, probably should have gone with Satin.
Still have to bolt down the bed, and tighten up the 4553 bolts that are in it.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline
Old 07-16-2017, 12:36 AM   #5585
VWNate1
VWNate1's Avatar
Post Bed Wood
The gaps are supposed to be very wide so the wood can swell in the rain.....
Look nice to me in green .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-16-2017, 12:26 PM   #5586
GRX
GRX's Avatar
New steering column bearings. Lower one was fragmented. So smooth now.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline
Old 07-16-2017, 05:42 PM   #5587
AussieinNC
Moderator
AussieinNC's Avatar
Spent the day angle lifting the bed on my daily driver...
2006 Silverado,,,new fuel pump, charcoal canister and fuel vent valve system...
Could not believe the amount of CRUD on top of the fuel pump unit....what genius decided to put the pump there????
Removed the four drivers side bolts, loosened the four passenger bolts, tailgate off, drivers side tail lamp wire plug and used my gantry lift to lift the drivers die of the bed up about 18 inches...wood blocks as safety pins...
Needed to replace the metal frame the charcoal canister sits in...GM wants $ 118...for a piece of sheet metal...yeah right....
30 minutes with the sheet brake and its as good as new...painted it up with Bed Liner...Sweet...
Now back to working on my 67 long bed...a real truck...
AussieinNC is offline
Old 07-16-2017, 06:13 PM   #5588
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Actually it was yesterday!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 07-16-2017, 07:02 PM   #5589
66clow
66clow's Avatar
You could always scuff the boards down with scotch brite pads. Looks way better
66clow is offline
Old 07-16-2017, 07:21 PM   #5590
FL71C10
Maybe I'll try that, thanks.
FL71C10 is offline
Old 07-16-2017, 11:24 PM   #5591
DarkFlounder
Pulled the front drive shaft and replaced the front axle pinion seal. Removed the u-joints from the drive shaft. Tomorrow after work shall be clean, reassembly and reinstallation.
Thanks to GM that the high hump is bolted in. Removing that made it a LOT easier to get at the bolts attaching the driveshaft to the transfer case yoke. Certainly easier than dropping the crossmember.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 07-17-2017, 08:55 AM   #5592
Smitty
Smitty's Avatar
Getting Closer!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline
Old 07-17-2017, 09:34 AM   #5593
Smitty
Smitty's Avatar
A couple more! Richard doing the body and paint with my brother Dale's help. Looking real good.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline
Old 07-17-2017, 12:58 PM   #5594
B Myers
B Myers's Avatar
Took mine camping last weekend, think she liked it.
Name:  C10 camping.jpg
Name:  C10 camping 2.jpg
B Myers is offline
Old 07-17-2017, 02:00 PM   #5595
GRX
GRX's Avatar
Put in new bed wood. I used pressure treated southern yellow pine boards. I had a hard time finding boards that were wide enough. Had to by 1 x 10 x 16' boards from a dock supply place. Painted both sides with POR15 ...
If I may ask. What is reason for painting wood with POR15?
GRX is offline
Old 07-17-2017, 02:18 PM   #5596
saxart
saxart's Avatar
Did you tow that big camper with that truck? I'm curious to hear how well that rig goes down the road.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline
Old 07-17-2017, 02:22 PM   #5597
toolboxchev
Probably a better choice than most of the canned crap at Home Depot, Lowes, and so forth.
Its supposed to seal so why not on wood???
toolboxchev is offline
Old 07-17-2017, 02:30 PM   #5598
B Myers
B Myers's Avatar
No the campground is close to home so I brought the firewood out in the old truck but I think I may install a hitch and brake controller and give it a shot sometime. I think it would do ok but that would be with careful driving and the load leveller setup properly and I'm good at getting things adjusted right so for me it may work but I do think it pushes the limit on the truck as it was designed but I don't go more than 45 miles from home and not in a hurry so that helps too.
B Myers is offline
Old 07-20-2017, 07:06 PM   #5599
indymachinist
Got the suspension stuff gathered up for powder coating. Hopefully I can find someone to do it for me reasonable.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline
Old 07-20-2017, 07:40 PM   #5600
FL71C10
Mar-k did a study on what finishes held up best over several years. The boards that were painted with POR15 and topcoated with regular paint were the only ones that didn't have any damage at all. That's where I got the idea.
FL71C10 is offline
Closed Thread
