BlahBlahBlah
Removing the spicer knobs?
So I found a really nice set of 3/4 ton hubs with the blue Spicer knobs in my stuff today.
I'm trying to take them apart and getting that stupid clip off that holds the Spicer knobs seems impossible. My e-clip tool doesn't want to do it, and various other attempts aren't working either. Is there a trick, or am I just being a dufus?
Re: Removing the spicer knobs?
Is the spicer hubs still on the axle or are you trying to remove just the blue dial from outer chrome ring?
Michael ![]() |
BlahBlahBlah
No its all off, just trying to take the clip off inside the chrome hub so I can slide out the blue knob.
Going by memory, you should be able to turn outer chrome ring that houses the blue dial upside down. Compress the large spring lightly to were you can push out metal pin running through the blue dial completely. You can use a smaller diameter size punch to push it through. Please be careful when removing the pin, you don't want to crack the plastic blue dial. Once the metal pin is removed it should all come apart.
Michael ![]() |
BlahBlahBlah
Yeah all of that part is done ... no damage lol. Now I want to get the blue spicer knob out and there is a e-clip or ring clip, not sure what everybody calls them. Anyway I cant get it spread apart in such a way that it will slip out of the grove it is in. This is all inside the chrome housing. Im assuming this holds the knob in. Ive been very carful not to put a tool anywhere on the outside of the knob to pull or pry with. Its a very close to perfect specimen.
Okay good, yes there is a snap ring holding the dial in the outer chrome ring and it's hard to remove. Here is a link that may help.
http://forum.73-87chevytrucks.com/sm...?topic=22710.0
Michael ![]() |
BlahBlahBlah
That is an excellent thread on dealing with taking these apart, lubing, and putting them back together. I bookmarked it. And as I was afraid, it said taking out those snap rings is a PIA lol. Looks like I just need to work it some more
Yes I agree, I found it a few years ago when I was working on a set of my hubs. Just had to find it again, Lol. We don't want to take any chances messing up a set of blue spicer hubs! That is my favorite part on the ole K20's.
Michael ![]() |
#9 | |
BlahBlahBlah
Thanks again for your help!
#10 | |
Michael ![]() |
