#1 | |
Re: numbers matching? original engine?
the machining process's were/are different fi vs carbs the lubes used or unavailable then vs the lubes used and avilable now and a comparrison simply based on the milage achieved then vs now is not entirely accurate my company had early 70'strucks that burned propane. these trucks regularly got upwards of 300k miles on them. many volvo's and mecedese benze's got easily close to 300k miles on them. no. not diesles either. I understand what your point is but milage alone is not the only factor that differentiates real engines from that 'other' type. many variables, variables not differences. FI does help atomise todays fuel that carbs seem to have difficulty atomising. |
#2 | |
![]() Join Date: Aug 2013
I am only a contractor That has had a bunch of chevy trucks, in the last 30 years Are you saying, if I rebuilt my 67-72 chevy engine And used today's lubes It would last longer? I don't know how to work on carburetor And Definitely not today 's fuel injection I don't even know how atomizing works My only conclusion Is The old trucks went around 100k(or a little more if you were lucky) And My mid 90's and up trucks Basically Go to 300k Just by changing the oil on time I was once told (Don't know if it is true or not) When emissions came into play All, the tolerances, had to be shored up on american vehicles Therefore They lasted longer Like Mercedes and Porsche Because, they were already ahead of us, by then My father in law was a European mechanic. He has always said Both of those cars have always been at the top Their(tolerances) Are almost like race engines |
![]() Join Date: May 2010
Regarding engine longevity, I agree with most of the reasons already stated including improved fuels and oils as well as improved tolerances, and machining. I don't recall anyone mentioning RPMs at highway speeds. Overdrive transmissions have reduced 65 MPH RPMs from about 3000 to closer to 2000. Hell, my '99 Vette with a 6-speed manual barely turns 2400 at 100 MPH!
#4 | |
Good point👍 Like everything else Everything Just gets perfected in time |
