Old 07-13-2017, 12:06 PM   #1
suburban99
suburban99's Avatar
72 K10 LQ4 swap overflow bottle question
Now that I have been driving my 72 for a couple of days I noticed antifreeze coming out of the overflow tube of the stock rad after I park it for a few minutes. Truck runs at 196f per my scanner...do I need an overflow bottle? Truck didn't have one when I bought it. What are you guys using? Pictures if possible thanks!
1962 C10 Longbox LS 5.3 4L60E----Sold$$
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped---sold
1955 f100 LS swapped----sold
1968 C10 shorty project
1971 C10 longy project
suburban99 is offline   Reply With Quote
Old 07-13-2017, 12:12 PM   #2
t300
Re: 72 K10 LQ4 swap overflow bottle question
For what its worth, I don't have one on my lq4. have stock fan clutch (no shroud) and it sits at 90c / 194f solid according to my Dakota Digital gauges. Overflow hose puked a bit after the first coolant fill and running but hasn't in the 3000km or so since.
t300 is offline   Reply With Quote
Old 07-13-2017, 05:50 PM   #3
ls1nova71
ls1nova71's Avatar
You dont need an overflow bottle, but without one you cant fill the radiator all the way to the top. This is the reason original radiators have the full level a few inches doen from the top, there needs to be room for expansion when the coolant is warm. If you over fill it, it will just puke out the excess then when it gets to the level it can safely hold it will stop, this will be the full level.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-15-2017, 09:53 AM   #4
Hart_Rod
Hart_Rod's Avatar
I just converted my wiper washer reservoir to my radiator overflow.
Hart_Rod is offline   Reply With Quote
Old 07-15-2017, 11:51 AM   #5
ls1nova71
ls1nova71's Avatar
Just don't take it to a Jiffy Lube type place or it'll likely get topped off with washer fluid!
Old 07-17-2017, 03:48 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 K10 LQ4 swap overflow bottle question
I have always ran a over flow tank on all 3 engines. It's just a good idea.
Where I work they have security guards that check the parking lot regularly. If they see the same vehicle puking anti freeze everyday they will put a sticker on it. After several times they will not let you on site with the vehicle until it's fixed.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
