Old 07-17-2017, 08:36 PM   #1
ab_70chevy
U joint question
Forgive my ignorance, but I've never had a u joint go out on me. I have a tapping noise coming from the rear on my '70 2wd right on take off and right before a complete stop. It gets faster with my speed and slower when I stop, but after about 5-10 mph you can't hear it anymore with the exhaust and road noise. Is the a u joint, or something else. Any other hints would be appreciated,
Thanks fellas
-Andrew
ab_70chevy is offline   Reply With Quote
Old 07-17-2017, 08:46 PM   #2
truckster
truckster's Avatar
Re: U joint question
Get underneath and try to move the end of the drive shaft by hand. There should be no play or looseness.
I'll bet your U joint is the culprit and it will be pretty obvious to you.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-17-2017, 09:30 PM   #3
bill3rail
bill3rail's Avatar
No way to tell unless you have hands on the UJ.
Amazing you have never had one go bad. I have had them go bad because I installed them where you cannot grease them so they dry up and destroy the bearings.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-17-2017, 10:56 PM   #4
ab_70chevy
Well I think I spoke too soon, I got it up on blocks and found the carrier bearing just a spinning. On to the drove shaft shop.
