07-18-2017, 10:11 AM | #1 |
Windshield Install Adhesive or no
OK folks. I've searched and searched and cannot find a definitive answer. I've even reached out to precision with no help.
When installing a windshield in a 67-72, is adhesive required/warranted? Precision states to watch their 50's year trucks of install video. when I asked them. They do put adhesive on their install for the 50 year truck window. But all the videos ive seen with install to the 67-72 is installed dry per say. Not to say soap/water isnt necessary for install but dry. No adhesive. Can anyone recommend dry or adhesive? If I recall the factory had some in the corners. |
07-18-2017, 10:26 AM | #2 |
Re: Windshield Install Adhesive or no
You want to keep your cab as water tight as possible, I recommend sealing the windshield. Use Bedding and Glazing Compound between the gasket and the body, and Window Weld Urethane between the glass and the gasket. Both items are offered by 3M, and available at your local parts store, or paint supply house.
07-18-2017, 10:32 AM | #3 |
I did buy some window weld urethane from 3m. So, as you mentioned between the window and the gasket. So just put a bead in where the window slides in all the way around the glass?
07-18-2017, 10:34 AM | #4 |
You want to put a bead of sealant all the way around the gasket in the groove the glass goes into, you are correct.
07-18-2017, 10:39 AM | #5 |
With the glazing compound when setting the glass around the pinchweld, wouldnt the gasket pull the compound inside with it when you do the rope trick?
07-18-2017, 10:46 AM | #6 |
You may get a little sealant on the rope, be cautious is my advise. When you have your gasket on the glass, and after you install the rope into the groove on the seal. Then put a 1/8 to 1/4 inch size bead of compound around the entire gasket in the fins of the gasket, that should hold most of the sealant from getting inside. Just take your time and again be cautious to where the sealant is and you will be good. Nitrile gloves are your best friend when doing this. put several layers of gloves on, when one gets sealant on it peel it off and keep going.
07-18-2017, 10:47 AM | #7 |
Thank you sir!
07-18-2017, 11:35 AM | #8 |
The Older Generation
Not sure you will be able to read it on here but this is what the '67-'72 Factory Assembly Manual says. If you have or buy the CD version of the manual it is in the area of pages page 65-67. LockDoc
07-18-2017, 11:54 AM | #9 |
Thanks LocDoc. I do have the assembly manual. I thought I recalled it having a sealer. But, I'm at work and couldnt recall.
Thank you for the image! |
07-18-2017, 12:06 PM | #10 |
just use some bedding compound in the area where the glass sits inside the rubber gasket. I would not use the 3m rubber urethane inside the gasket.
07-18-2017, 12:11 PM | #11 |
If you use urethane windshield weld to install your windshield you will end up with one huge mess not to mention it was never used as an original sealer on these trucks . follow the instructions posted by Loc doc , using
http://www.3m.com/3M/en_US/company-u...3194048&rt=rud |
07-18-2017, 12:49 PM | #12 |
Do not use urethane on this windshield! It was not designed for urethane. Best case scenario is you get a huge mess that's going to be difficult to clean up. Plus it will be impossible to replace your windshield in the future without destroying the gasket.
Having owned an automotive glass shop, I can tell you that I never used sealer of any kind on these windshields except for 4 or 5 inches at the top corners. You want to use a non-hardening butyl rubber sealant.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-18-2017, 12:54 PM | #13 |
Old member
I have 2 trucks and neither one has any sealer in them and neither one leaks. The 71 is always inside but the 67 ramp is parked out side all the time. It hasn't leaked anymore since the new windshield this past winter was installed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-18-2017, 01:20 PM | #14 | |
I actually don't use sealer on mine either except for 6 inches over and 3 inches down from the top corners, but I remembered seeing this page from the Ass'y Manual so I thought I would post it up..... LockDoc
07-18-2017, 01:35 PM | #15 |
Thanks guys. Scared as hell now lol. I will just use the budding compound
