Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 06-22-2017, 12:55 PM   #1
CK5
CK5's Avatar
ISO - rear seat floor plates etc..
Looking for the 4 rear seat floor plates as well as the 2 captured nut plates for mounting the front of the rear seat.
Also need the 6 bolts used to bolt the rear seat down. Attached pics of what I'm looking for, thanks.
CK5.com
1972 Blazer Build
CK5 is offline   Reply With Quote
Old 06-25-2017, 05:50 PM   #2
Blazerowner
Blazerowner's Avatar
Re: ISO - rear seat floor plates etc..
You would be better off making them yourself. That's what I did. You can buy those cage nuts from McMaster car far pretty cheap. I bought some sheet metal stock from tractor supply and cut the plates myself. Hard to tell it's not original and my blazer didn't come with a rear seat.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 07-17-2017, 09:12 PM   #3
1rippen6
I found 2 they do have some pitting I probably have the nuts also but would have to empty out the blazer and see if they are still there. I can't look underneath they sprayed the underneath with spray foam. Do you also need the channel that goes underneath for the rear seat mounts?
1rippen6 is offline   Reply With Quote
Old 07-18-2017, 03:04 PM   #4
CK5
CK5's Avatar
I might be interested in the underneath channel as long as it is from a 71-72.
CK5.com
1972 Blazer Build
Old 07-18-2017, 03:07 PM   #5
1rippen6
Yep, has to be from a 71 or 72 never owned a 69 or 70. I have plans tonight will post a picture tomorrow.
Old 07-18-2017, 03:08 PM   #6
1rippen6
Do you still need the other parts or are you good.
Old 07-18-2017, 03:16 PM   #7
CK5
CK5's Avatar
Thanks, I'll let you know, going to check out some local part outs this week.
CK5.com
1972 Blazer Build
Old 07-19-2017, 09:34 PM   #8
1rippen6
Here is the channel it had a broken bolt so I welded a nut on what was left and heated the nut up. Threads look fine on all 4 nuts does have some pitting but no thin spots. 60 plus shipping if interested send me you zip and I will get a shipping quote.
Old 07-21-2017, 07:53 PM   #9
CK5
CK5's Avatar
Thanks for the pics 1rippen6, I was able to get all the parts I needed today locally.
CK5.com
1972 Blazer Build
Old 07-21-2017, 11:10 PM   #10
1rippen6
No problem
Old 07-23-2017, 08:40 PM   #11
2006gmcdmax
I'm searching for that lower channel too for my 72 Blazer. I'm willing to pay up for a clean one like the one in the picture.
2006gmcdmax is offline   Reply With Quote
Old 07-23-2017, 09:54 PM   #12
1rippen6
PM returned
