Where to got captured door panel nuts
On my 70 passenger, 2 of the 4 captured nuts that the lower door panel screes thread into, are gone. not in the bottom of the door. And a 3rd one I have to put tape on to keep from falling into the door when I remove and install the door panel.
I believe they are just wedged in there and not welded. Over time, the metal in the door changes shape and not longer holds them. Where can I get replacements? Thanks in advance.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Dec 1999
Re: Where to got captured door panel nuts
Contact ToPeCo Products. They are in National City, Ca. 800-266-9314
2525 Southport Way, Suite H National City, Ca. 91950 They handle a lot of OEM fasteners. If they don't have them they may be able to tell you where to get them. Good Luck Bet they're still open!
Smitty '71 Short Fleetside Spring Valley, Ca. Last edited by Smitty; 07-19-2017 at 07:18 PM. Reason: Forgot something. |
![]() Join Date: Apr 2016
I was wondering about that myself. I had one that was rusty and busted out and beyond hope of putting back in. All I had was a square hole. By accident at the hardware store I found cage nuts. I thought they were interesting so I bought one for a few cents. it turned out to be just what I needed. I have not yet installed my door panels. Here is what one of those welded in or pressed in factory nuts looks like, and the cage nut. They are 1/4-20 thread size.
Its a Truck Thing......
Ace Hardware has the caged style in their bolt bins. At least the ones I have visited did.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
fastenal
I got mine from the hardware store. They were just called license plate nuts. I tacked them into place.
![]() ![]() Join Date: Feb 2009
You may find them here. https://www.auveco.com/
Once you have a description, check for retail. I don't think Auveco sells retail.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Carpe manana
![]() ![]() Join Date: Dec 2010
I got a set from board member and vendor Wes Hepp at Classic Heartbeat.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
A good hardware store has many sizes. Do not wast your time in chain stores!
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Big Block
![]() Join Date: Jun 2014
Demian5 - PM me your mailing address and I'll send you some. 8 enough?
Randy |
That is so money right there!
Where's my beer?
Use plastic license plate clips. Readily available at any parts store, and cheap. That's what I've used on my doors and they work great.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Fastenal has everything or can find it for you
Stan 67 swb BLU MULE posted via flip-fone |
#15 |
Demian5 - put them in the mail to you yesterday...
Randy |
