Old 07-22-2017, 09:43 AM   #1
Clyde65
Clyde65's Avatar
L83/6l80 going into 64 Crew Cab
Morning all!
Picked up a 2014 l83 and 6l80e yesterday to go into dad's crew cab. His 350/7004r just isn't cutting the mustard and needs to go.
Asking for any concerns or roadblocks before we get started. Gonna go with a Walbro 255 and probably some hooker LSX headers, dingo sliders...am I missing anything?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-22-2017, 09:46 AM   #2
Clyde65
Clyde65's Avatar
Re: L83/6l80 going into 64 Crew Cab
Dad's crew
Clyde65
Rebuild of Clyde
support our troops!
Old 07-22-2017, 12:01 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Originally Posted by Clyde65 View Post
Morning all!
LS headers don't bolt up to an l83..
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-22-2017, 01:58 PM   #4
mongocanfly
mongocanfly's Avatar
why would headers not fit the engine...a L83 is a 5.3..am I missing something?..
btw..nice crew cab clyde
Old 07-22-2017, 08:37 PM   #5
ls1nova71
ls1nova71's Avatar
Because it isnt an LS engine, its a new LT, there are a lot of differences. Should be a cool swap!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-22-2017, 08:46 PM   #6
mongocanfly
^^^^ohhhh...ok^^^^...thanks for clearing that up..I was unaware they changed anything
Old 07-22-2017, 09:05 PM   #7
Clyde65
Clyde65's Avatar
Thanks for that! I'll look into that!
So if it's like an LT motor do regular LT headers work?
Clyde65
Rebuild of Clyde
support our troops!
Old 07-23-2017, 12:09 AM   #8
Clyde65
Clyde65's Avatar
Thanks mongo, wish it were mine! It's my dad's!
Clyde65
Rebuild of Clyde
support our troops!
Old 07-23-2017, 10:03 AM   #9
ls1nova71
ls1nova71's Avatar
If you're talking about an LT1 from the 90's, no, theyre gen2 small blocks. The new LT's are gen 5, dont ask me why GM cant come up with new names instead of reusing old ones but remember there was alos an LT1 from arround 1970! Member 87chevy.com has a thread on here where he's putting a new LT engine in his truck, you should take a look at it.
Old 07-23-2017, 11:22 AM   #10
87chevy.com
Not without a sledge hammer.
Old 07-23-2017, 12:57 PM   #11
Clyde65
Clyde65's Avatar
Hahahaha! I have several...ummm....persuasion tools!
Clyde65
Rebuild of Clyde
support our troops!
Old 07-23-2017, 12:57 PM   #12
Clyde65
Clyde65's Avatar
Thanks for that, I thought I had seen one on it recently.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-23-2017, 03:33 PM   #13
Tork?
This thread has a lot of info on the L83.
http://www.lingenfelter.com/forum_li...mponent-images
May need to rethink the fuel situation. According to it:
"The L83 runs a mechanical fuel pump off of an extra lobe on the camshaft. The pump is mounted at the back of the engine in the valley. The pump is fed low pressure fuel by a PWM controlled electric fuel pump mounted in the fuel tank."
There are pics in the link
Tork? is offline   Reply With Quote
Old 12-12-2017, 08:26 PM   #14
Bczik84
Well did it work?
Bczik84 is offline   Reply With Quote
Old 12-12-2017, 08:37 PM   #15
Clyde65
Clyde65's Avatar
Yep, got it!
When I emailed Speartech about the new Gen V motors to see if there was anything special required for the fuel pump, they said you just want to spec a pump that is capable of supporting around 75 psi, with a good flow rate.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-12-2017, 08:38 PM   #16
Clyde65
Clyde65's Avatar
Originally Posted by Bczik84 View Post
Well did it work?
I’m going real slow. Hopefully have it done in a few more weeks.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-22-2018, 02:33 PM   #17
chris1htx
Any update on this build?
chris1htx is offline   Reply With Quote
Old 08-08-2018, 02:19 PM   #18
mcbassin
Still Learning
mcbassin's Avatar
Subscribing ....
Old 08-09-2018, 02:24 PM   #19
Daaaanz67
Nice truck watching this one.
Daaaanz67 is offline   Reply With Quote
Old 08-09-2018, 09:09 PM   #20
Clyde65
Clyde65's Avatar
Yes, will throw in some pix in a few days.
We had real bad issues getting the trans calibrated, I think it was a harness issue but no one will admit to that.
Got the tuning all done and then had to wait, 105 plus heat I just can’t do any more!
Got the harness back on, TCM back in, PCM in and she fires! Yeah!
But! Always a but, the Bosch fuel pump is screaming like a banshee! I’m told now it needs -8 or larger fuel line( Geesh!) also not sure if the pump is actually below the fuel level, so tomorrow or Saturday maybe.
Now putting in the Speed Hut CanBus guages( must use the canbus guages)
Took it out for a short drive to make sure it was shifting right.
Plenty more to do. I’ll put a parts used list up when I get the big boy squared away.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-10-2018, 08:05 AM   #21
nsb29
nsb29's Avatar
Just got back from Southern Cal average temperature was 113 really hard to get motivated when its that hot especially with humidity around 30% love your dads truck Would like to see more pictures of it as well as your install
nsb29 is offline   Reply With Quote
Old 08-10-2018, 10:19 AM   #22
87chevy.com
I'm running a walbro F10000302 in the stock tank and location, sounds like a normal factory intank pump. Running an external 5 bar regulator, all -6 an lines. Glad to hear the trans issue is sorted.
Clint
Old 08-11-2018, 02:22 PM   #23
Clyde65
Clyde65's Avatar
Thanks Clint and nsb29, I am working on moving the pump, adding larger feed line for the pump and then guages. Never ends!
And I have to put my truck back together after paint!!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-16-2018, 10:41 AM   #24
Clyde65
Clyde65's Avatar
Tease picture!
Clyde65
Rebuild of Clyde
support our troops!
