Old 07-23-2017, 09:10 PM   #1
vikingsandpintos
Junior Member
What is this silver box by the fusebox?
Hello again!
Working on my daughters 67 C10 some more. Been having some electrical issues, but think I have it narrowed down to the battery (Which was new! lol)
I do have a question... When I first hook the battery up, this silver box clicks. Each time I pull the neg cable off, then put it back on, it clicks. What is it, and should it click everytime I hook up the battery? It is to the right of the fusebox on the firewall. Thanks!
vikingsandpintos is offline   Reply With Quote
Old 07-23-2017, 09:19 PM   #2
chiefcfd
chiefcfd's Avatar
Re: What is this silver box by the fusebox?
That is the relay for the horn.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 07-23-2017, 09:25 PM   #3
vikingsandpintos
Junior Member
Is it supposed to click when I hook up the battery? The horn button in the steering column isn't hooked up, it has a smaller aftermarket steering wheel on it with no horn, I assume the wire is just "In there" somewhere in the column....
Old 07-23-2017, 09:29 PM   #4
chiefcfd
chiefcfd's Avatar
The wire may be grounding inside the column. If you are not using the horn you can unhook the relay.
Old 07-23-2017, 09:49 PM   #5
hotdog hound
From the look of the wiring someone may have installed a remote horn button. I had horn issues ended up the turn signal lever retaining screw in the steering wheel had come loose so I had to pull the wheel to tighten I live in a big city definitely need my horn.
hotdog hound is offline   Reply With Quote
Old 07-23-2017, 10:19 PM   #6
vikingsandpintos
Junior Member
The previous owner had did some "Creative" wiring.. lol.. So I assume the clicking means the wire in the column must be grounding? I want to hook up a horn in the future with a different steering wheel, but for now won't be using a horn. So I can just unplug it without it affecting anything else till I can get to hooking up a horn button?
Old 07-23-2017, 10:45 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Yes, you can unplug it. If the horn was hooked up it would be blowing all the time. (if the horn itself actually works)
LockDoc
Leon
Old 07-24-2017, 11:03 AM   #8
harpo231
harpo231's Avatar
Is this a NO or NC relay ,, could account for clicking when energized
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-24-2017, 11:24 AM   #9
biketopia
Should be normally open
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 07-24-2017, 11:32 AM   #10
demian5
demian5's Avatar
And then wrapped it in roofing tar!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
