Old 07-23-2017, 02:25 PM   #1
ghalperin
ghalperin's Avatar
Big Block Bellhousing Crossmember for manual transmission
Does one exist specifically for big blocks?
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 07-23-2017, 02:33 PM   #2
randy500
Re: Big Block Bellhousing Crossmember for manual transmission
I think the bellhousing for a big block could be machined differently, anyone have a known big block bellhousing for pictures?
randy500 is offline   Reply With Quote
Old 07-23-2017, 10:50 PM   #3
T-bags72
I swapped out the 350 for a 454 and it bolted up perfect. Don't know if original bbc trucks are different but SBC works without any issues. I even used same bell housing for my m21 swap. If u needing one I have an extra that I don't need.
T-bags72 is offline   Reply With Quote
Old 07-23-2017, 11:34 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If you are giving it away no problem, but you can't sell parts on here unless you are a paying member and your name is in Blue. Click on the word "Subscribe" in the menu bar above and it will list the different subscription options.
Thanks.
LockDoc
Leon
Old 07-24-2017, 07:54 AM   #5
Mike C
Mike C's Avatar
Yes. The big block manual trans crossmember exists, and it is different. Not near as many big block manual trucks as small blocks so they can be hard to find. Not sure what all the additional parts you need are, but clutch pushrod from pedal to z bar, z bar, fram bracket etc. are all different if I remember correctly. High hump floor has different location for shifter hole as well.
I looked for a long time to find all these parts when I was going to convert my 70 Sierra Grande to manual.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-24-2017, 10:08 AM   #6
randy500
I find your post to be very credible. I never considered the floor hi,p being different but I now know it would also be different since the trans sits a little further back with a big block. Thank you for the information
