Cab mount relocation
Hi I chopped the frame down to a shorty and now need to relocate the cab mounts. Is it better to install once cab is on frame or to do it before I put it back on. I just want to make sure that before I drill I have the correct location.
Re: Cab mount relocation
I did the same thing cut the frame.Did the cab mounts before i put the cab on.
Do You remember the measurements?
I think it was 12 inches.I will check on it on monday.
I'm just glad to be here!
This might help...
The center of the rear cab mount should be 41.63" (41 5/8") back from the center of the front cab mount.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
