Old 07-23-2017, 07:54 PM   #1
69GMCLonghorn
69GMCLonghorn's Avatar
Power Steering pump woes
So on a 70 C-10, my P/S pump has crapped out. Every single place I go or check online doesn't have the right pump. The fitting in the back points in the wrong direction. Or the reservoir is the larger one with more of an integrated look, rather than the original one that has a top on it more like a wide snorkel. I think it's called a Saginaw type. I installed the new one and now it's offset from the crankshaft pulley by about 3/4 of a belt width.
Does ANYBODY know where I can pick up a new (rebuild from Thailand??) original style pump for this thing?! I've fought too long with it and I'm almost out of booze. Help!
69GMCLonghorn is offline   Reply With Quote
Old 07-23-2017, 10:17 PM   #2
El Dorado Jim
Re: Power Steering pump woes
sub'd
El Dorado Jim is offline   Reply With Quote
Old 07-23-2017, 10:52 PM   #3
franken
Get a bare pump and put your res on it. Make sure the pully mounts the same.
Old 07-24-2017, 01:40 AM   #4
FirstOwner69
FirstOwner69's Avatar
Did you try Rock Auto?
http://www.rockauto.com/en/catalog/c...ring+pump,7380
FirstOwner69 is offline   Reply With Quote
Old 07-24-2017, 07:56 AM   #5
Mike C
Mike C's Avatar
Yup. This. No need to replace your reservoir unless it is damaged somehow.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-24-2017, 12:05 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Hard to locate complete Chimany style pumps in a parts store anymore. The last one I rebuilt: bought the pump, pulled the resivor off the back of old one, cleaned it up, sealed it on the new pump. No issues.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-24-2017, 09:15 PM   #7
franken
NAPA shows 2 w/o res, and one with.
NNS 84691
NNS 81691
One has a core charge and the other doesn't.
No idea how or why people can't go to their local parts store websites and check for common parts. I guess its better to waste a few days on this site, rather than find the part in a few minutes.
Old 07-24-2017, 09:20 PM   #8
harpo231
harpo231's Avatar
Just tryin to participate maybe, But he did say he had gone to look and on the internet ,,,
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
