Old 07-26-2017, 10:08 AM   #1
carnut$
Stock C10 tank w/ efi
I installed a '94 LT1 EFI 350 into my '71 shortbed. I'm using the stock behind the seat fuel tank w/eec. I'm running and external FI pump. I've plumbed the pressure side from the stock (single line) sending unit, and the low pressure return through the passenger side/top tank tube. I'm wondering if my vented gas cap is "breathing" enough. Sometimes the truck will rpm surge & sometimes even die, making me wonder if it's vapor locking.
carnut$ is offline   Reply With Quote
Old 07-26-2017, 10:34 AM   #2
ga-stepside
ga-stepside's Avatar
Re: Stock C10 tank w/ efi
I have a LT1 in my 280z. How much pressure are you getting at the engine? It should be 40-43 psi. Plus is the pump close to the tank. electric pumps don't pull well, they are designed to push. How big is your input line to the engine? It should be 3/8 with the return no smaller than 5/16.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 07-26-2017, 10:53 AM   #3
carnut$
I mounted the pump down on the frame rail (under the dvrs door). Gauge at the fuel rail reads 42 lbs.
Pressure side into engine is 3/8" & fuel return is 5/16".
The surging is very sporadic, as well as the dying. Most of the time it runs perfect.
Old 07-26-2017, 11:07 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Stock C10 tank w/ efi
At the time it does this is the tank near empty? Could be loosing fuel pressure from the tank side if in a curve are very low on gas.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-26-2017, 11:24 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
When it surges can you remove the gas cap while running and it "fixes" the problem?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-26-2017, 01:06 PM   #6
carnut$
It does it so infrequently, it's hard to pin it down. Yesterday it did it parked/running perfectly still in the driveway. I wished I'd thought quick enough to remove the gas cap then to see if it recovers.
Old 07-26-2017, 04:05 PM   #7
anew4961
I went through all this on a rear mounted tank. the fuel pump needs to be as close to the tank as you can get it the tank does need to be vented outside of the cab and have a good return line. you can get sending units with two lines
anew4961 is offline   Reply With Quote
efi, fuel, injection, tank, vented
