Old 07-26-2017, 05:27 PM   #1
67see10
67see10's Avatar
Best gear ratio for lq4 or lq9 w/ 4l65e
What will be the best gear ratio for a 6.0 ls swap with a 4l65e in a 67 c10.
The truck will be use both for city and occasionally highway use.
67see10 is offline   Reply With Quote
Old 07-26-2017, 05:53 PM   #2
Devil Pup
Devil Pup's Avatar
Re: Best gear ratio for lq4 or lq9 w/ 4l65e
I'm by no means an expert but it will depend on specific factors on your vehicle. main thing your missing is your tire size. . This calculator might help you.
http://www.angelfire.com/fl/procrastination/rear.html
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 07-26-2017, 06:52 PM   #3
72MARIO
72MARIO's Avatar
Tire height plays a huge role in rpm. I have a 27" tire and 3:42 in my suburban It needs more rpm for performance and towing. Cruise on freeway it's great.
Same goes for my work truck it has 32" tire and 3:73. It needs at least a 4:11 to work the way I wish it would. Even a 4:56 wouldn't be out of the question.
Play with the rpm calculator and decide what you want most out of the truck. Hwy cruiser or performance hauler. Remember the Denali trucks came with 4:11 and 32" tire and they are quick.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-26-2017, 08:06 PM   #4
67see10
67see10's Avatar
I won't run anything bigger than a 29" tall tire. I don't see myself hauling anything with this truck. It will be bagged and on a PB Extreme drop member
Old 07-26-2017, 08:17 PM   #5
jocko
jocko's Avatar
3.73
Old 07-26-2017, 08:40 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Best gear ratio for lq4 or lq9 w/ 4l65e
My LQ4 has the 4 l80e behind it along with 4:10 gears. Highway is 16-18 MPG and the stop light to stop light is fun also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-26-2017, 08:59 PM   #7
72MARIO
72MARIO's Avatar
My truck is bagged too
2005 TAHOE DD
Old 07-26-2017, 09:10 PM   #8
trac209
72mario,cool setup!
trac209 is offline   Reply With Quote
Old 07-26-2017, 09:21 PM   #9
67see10
67see10's Avatar
That's sweet! Bag the camper as well
Old 07-26-2017, 09:22 PM   #10
67see10
67see10's Avatar
why did you decide to go with the 4l80e?
Old 07-27-2017, 06:29 AM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Best gear ratio for lq4 or lq9 w/ 4l65e
Because I bought the whole setup out of a 04 heavy duty with 70,000 miles on it.
Old 07-28-2017, 07:48 PM   #12
Kennuck
Kennuck's Avatar
What Jocko said.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 08-14-2017, 12:36 AM   #13
Dan in Pasadena
Dan in Pasadena's Avatar
What size tires?
My '55.2 has same LQ4/4l85e combo but 3.73 final rationand 235/55x17 tires so I wonder how it'll do for mpg and mileage as well?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-14-2017, 06:35 AM   #14
Andy4639
Old member
Andy4639's Avatar
My trucks info is all right here. When I took it to the tunner and put it on the DYNO machine he said the 4L80E takes a lot of HP to operate. My HP # was @290. All stock except for header's.
Old 08-14-2017, 07:08 AM   #15
krue
Designated A-hole!
krue's Avatar
What brake setup are you running?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-14-2017, 07:41 AM   #16
67 chevelle
67 chevelle's Avatar
I have 3.73s in both of mine ,one with overdrive 200-4r , and one without turbo 350 , both work great with 29 inch tires
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-14-2017, 11:02 AM   #17
weq92f
weq92f's Avatar
3.73
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
