Carrier Break Question
The charts I read say that there's a carrier break at 4:10 down/ 4:56 up. My spid in my 85k20 says I have 4:11's. I'm wondering if those gears will work in my cucv axles with the 4:56 carriers?
Re: Carrier Break Question
Short answer will be no. First problem is that from the factory you should have a 10 bolt front and possibly a 9.5 semi float 14 bolt rear. The second issue is both the full float 14 bolt and Dana 60 have a carrier break at 4.10/4.11 and 4.56. Now would ideally be the time to re ratio them, but you are then looking at a bit of money for the bearings/carriers/gears/labor. Depending on the final combo you run, your CUCV axles may work just the way they are.
Is there something wrong with the 4.56 gears?
The difference between 4.11 and 4.56 is about 10% (which does NOT equate to 10% better gas mileage). Unless you're repairing something that is broken, I'm not sure I'd bother with the expense and hassle of swapping for a minor change like that.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
