Old 07-30-2017, 10:40 PM   #1
c20pickup
symptoms of flattened cam?
what are the symptoms of a flattened cam lobe?
heres the backstory, ive got a freshly rebuilt 350 in my 70 c20. i had a local machine shop do the long block and i assembled the rest. the cam is a crane hydraulic flat tappet with matching lifters. i had the engine broken in at the machine shop in the chassis. it was ran between 2000-2200 for the 20 minutes. since the rebuild ive ran nothing but valvoline vr1 with a bottle of zinc additive. changed the oil after break in and repeated. the engine now has about 250 road miles on it and ran great until tonight. i was over visiting family and when i went to leave i got the old "do a burnout!!" so i whipped it around in the culdesac and went on my merry way. on the way home i noticed the engine was running rough and had an obvious misfire. after checking all the plug wires and all the obvious when i got home i also noticed a ticking/clicking noise coming from the valve train. so i pulled the cover and discovered the rocker on the intake valve for #5 cylinder had come loose and was no longer on the valve where it was supposed to be. the nut on the rocker arm didnt seem to back off because it had about the same threads showing from the stud as the rest of the rockers did. so i went through the procedure to reinstall and adjust the rocker. now to get the right adjustment on the valve the nut is almost bottomed out on the stud and has about twice the threads showing as the rest do. so i put it all back together and fired it up and still had the same ticking/clicking noise coming from the valve train. so in disappointment and disgust i slammed the hood and pulled it back into the garage. i should add that on the way home i noticed a plume of smoke coming from the left tailpipe, like a bluish white (maybe burning oil?) after taking off from an idle. any advice on what to look for or check next would be great!
c20pickup is offline   Reply With Quote
Old 07-30-2017, 11:00 PM   #2
Custom/20
Custom/20's Avatar
Re: symptoms of flattened cam?
Either you flattened lobe or pulled a rocker stud. The runability could also be a number of things ranging from a burnt valve to a blown head gasket. I would double check your rocker stud lengths and do a compression test.
Custom/20 is offline   Reply With Quote
Old 07-30-2017, 11:35 PM   #3
c20pickup
the heads are from 1978 and were also completely rebuilt. i believe 1978 would be screw in instead of press fit, correct? i didn't think the threaded in studs had an issue with pulling out.i did pull the rocker off and look at the stud, it wasn't loose but i didn't measure it either. i will double check tomorrow, thanks for the suggestion.
Old 07-31-2017, 07:45 AM   #4
Not that I know of. I'd check them.
Old 07-31-2017, 01:12 AM   #5
saxart
saxart's Avatar
Collapsed lifter?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 07-31-2017, 04:49 AM   #6
toolboxchev
I would be betting ( unfortunately ) on a pulled stud.
Ask me how I know this? re-adjustment and fresh oil change fixed my issue. P.S. too much zinc is a bad thing...done way too much research and affirming the levels in regular ZR1 is enough for 70 k on a Comp Cam and Lifter set up.
Hope it goes well, with no major damages. Please let us know, plenty of folks here to help.
Also betting on those heads have press in rocker studs. Get the casting numbers to verify.
toolboxchev is offline   Reply With Quote
Old 07-31-2017, 09:07 AM   #7
randy500
Screw in studs are obvious as they have a nut built into the stud st the base. They were only standard in hi po engines. Put a straight edge across the studs to see if one pulled out.
Hammering it back in won't solve the problem so it will need to be pinned or tapped for screw in stud.
randy500 is offline   Reply With Quote
Old 07-31-2017, 03:58 PM   #8
GRX
GRX's Avatar
Exactly as randy500 said above ^^
And if the heads have been degreased in an oven at too high a temperature it can relieve the press fit on the studs making them pull out easier.
Also ... if using Valvoline vr1 why add a bottle of zinc additive? More is not better. In fact, too much ZDDP can create a corrosive condition and is source of many cam/lifter failures.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-31-2017, 04:47 PM   #9
cypressbog
Go Pack Go!
I'd get that truck back to the shop that did the work.
cypressbog is offline   Reply With Quote
Old 07-31-2017, 08:15 PM   #10
Blue GMC
Blue GMC's Avatar
Originally Posted by cypressbog View Post
i'd get that truck back to the shop that did the work.
x3
Blue GMC is offline   Reply With Quote
Old 07-31-2017, 05:52 PM   #11
jjzepplin
jjzepplin's Avatar
x2!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-31-2017, 08:31 PM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Usually a lot of glitter in the oil. Pull valve covers, check the corners of heads. Dip your finger in oil, rub around. Look at finger, if you see the glitter and the bigger the particles, quicker its denigrating.
If not, as stated above.
D.PASSMORE is offline   Reply With Quote
Old 07-31-2017, 09:29 PM   #13
c20pickup
upon further inspection tonight i pulled a rocker stud out of the head. didnt even think to check that last night because i always assumed i had screw in studs. now the trick is to get the stud out.. some of the threads appear to be galled up and stripped. this is gunna be fun. could be worse... i guess. i appreciate everyones help
Old 07-31-2017, 09:47 PM   #14
AussieinNC
Moderator
AussieinNC's Avatar
I have been following along...and have some suggestions....
1/ Back to the shop that did the work, especially the head work....the remaining pressed in studs will most likely work their way out...symptomatic of too hot a cook when the heads were tanked...the press in studs need to be all removed and the stands machined for screw in studs...pinning them and or set screwing them will just weaken the stand...
2/ Make sure the push rods are not bent...
3/ Make sure the valve springs have not collapsed ...
4/ Make sure the valve stem seals have not collapsed...some shops just use umbrella style seals, rather than fixed style. This could be the smoke when taking off after idle...
5/ The cam lobe and that lifter could also be damaged from the lack of lifter contact pressure...the lifter is kept in contact with the cam by light pressure from the valve spring and the internal valving inside the lifter...
6/ Also the oil pump needs to be checked for metal contamination...
Personally, I would be pulling the engine and replacing the heads with an aftermarket set of alloys...use studs instead of head bolts and replace the cam and lifter set ....
AussieinNC is offline   Reply With Quote
Old 07-31-2017, 10:24 PM   #15
rockyrivermark
Right. Why put any money into smog heads anyway.
Make the shop fix it, that's obviously your first move.
Or buy good heads and make the shop install them.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-31-2017, 11:00 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Lots of good advice! My take- I've threaded a head for an individual threaded stud in the past, but that was mostly on old iron, not necessarily something that had been to the machine shop. I'll be honest and admit that I've never heard of a hot tank being too hot, but even with some raised boiling point from the lye, the tank can't be hotter than 260º, which temperature I've seen even big blocks survive, if the coolant was kept liquid. I've had mine to 230º while towing my trailer up a long hill, with no ill effects. Both metals have essentially the same thermal expansion coefficient, though, so I have reservations about that one being a stud pulling reason.
~Steven
Simi Valley, CA
Old 08-02-2017, 05:40 AM   #17
GRX
GRX's Avatar
Hot tank, no. Oven, too hot, yes. Most shops had to switch from lye tanks for environmental reasons. We did years ago. Sure do not miss the caustic tank. Have scars on my arms & missing nose hairs from that crap.
Boogered threads mean replace the stud. Puller tools can be bought, or perhaps you can borrow one locally. Drill and pin the new one as suggested above. And remember that factory style swedged rocker nuts are only meant to be used once. Buy a new one or go ghetto and smack the nut with a hammer or squeeze in a vise.
Old 07-31-2017, 11:09 PM   #18
c20pickup
really appreciate the response. this has all ran through my head already. last night i was so ticked off i was ready to pull my dad's 427 off the shelf and drop that in the truck. i wont be going back to the shop that did the machine work. it was the first time i had used them and did not have a good experience with them, AT ALL. long story short, when i had this engine rebuilt i was fairly uneducated on how to make an engine really make power... hence why i have rebuilt crappy smog heads on my fresh engine.. after the reconditioning of the heads was all said and done i could have had a nice set of aluminum heads for about 100-150$ more. why the machine shop did this to me still baffles me, but probably because they had a larger profit in the machine work and shop labor than they would have if they just sold me a new set of heads. im just going to take my lumps on this one i dont want to be had again. ive already thought that if this stud issue happens again (which im sure it will) i will be removing the engine and giving the top end some new heads. and like stated above i dont want to put any more money into a set of garbage heads than i have to. id like to stick with iron heads so if anyone has some suggestions on some good 64cc iron heads let me know! for right now though i think i will flush the oil and stick a bore scope down the pushrod hole and look for damage. i didnt see any metallic on the dipstick or my finger last night when i checked it while it was hot. there was no apparent damage to the pushrod, rocker, or valve stem.
Old 07-31-2017, 11:51 PM   #19
rockyrivermark
Yep. Move on. So I'm in a similar situation
I have an original '70 350 runs great. Previous owner took the heads off and sold me the truck with '78 smog heads on it. He was upfront about it when I bought the truck and since become somewhat friends.
I don't want aluminum and going to buy these cast heads from summit racing. They are made by Dart and seem like a good value.
Mine truck or just a nice driver. Gets up and really goes already but I want to put better heads on it next winter.
Cool thing is summit racing in Ohio is 40 min from my house. Not sure if free shipping applies to heavy time such as this.
Here's the link
https://m.summitracing.com/parts/sum-152123/none/images
Old 08-01-2017, 09:23 AM   #20
biketopia
You'll need a different intake, but for the price you can't beat these http://www.jegs.com/i/JEGS-Performan...14005/10002/-1 Vortec heads are by far the best cast iron head for the money, they will support over 400hp right out of the box. Summit has their version made by dart for like 85 more than these. These are jegs house brand, but im betting they are re-boxed GMPP or Dart, I'm sure a quick inquiry to their tech line would let you know, I asked some questions on them a while back before I found a smoking deal on set of vortec heads and intake near me or else these would be on my engine. And yes free shipping applies to them.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 08-01-2017, 11:49 AM   #21
67 chevelle
67 chevelle's Avatar
If your buying heads for a small block , vortecs are the way to go , dart iron eagles are nice also , check your combustion chamber volume , the heads you listed are 72 cc[low compression , most performance 350 heads are 64 cc
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-01-2017, 09:31 PM   #22
c20pickup
ive been looking at aftermarket irons, and vortecs did cross my mind, but somewhere i thought i remember there being more to the conversion than just the intake and valver covers, i could be wrong though. i know im shooting for a 64cc head, because from what im told that will give me 10:1 comp with the flat top pistons i have. i just wasnt sure about intake runner size and all that good stuff
Old 08-02-2017, 07:18 AM   #23
biketopia
Nope that's it, valve covers and intake are all you'll have to change. Both stock castings are good, the ones that come on some of the 2500 trucks got a bad rep for being poor flowering on the exhaust side because the "062" are that damn good, plus the internet said so and HotRod did a story claiming the "906" were were less superior than the 062 but that's not the case.
Here's a bunch of info on vortec's for you to read up on.
http://nastyz28.com/threads/vortec-c...e-guide.56505/
http://www.superchevy.com/how-to/97458/
http://www.superchevy.com/how-to/678...cam-355-build/
Old 08-01-2017, 11:59 AM   #24
demian5
demian5's Avatar
Use a hammer, put the stud back in, drill a hole at an angle to the stud and put a roll pin in (commando style was just to break the drill bit off)...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-01-2017, 01:24 PM   #25
toolboxchev
Only for the lonely Captain! Love it, fricken funny man!
