Old 07-30-2017, 04:35 AM   #1
Bennydog
Bennydog's Avatar
Rear flip kit bump stop ?
I know this has been done to death but though I would ask. I just got done doing a 4.5 / 6 inch kit from Western Chassis. Up front i did 2.5 spindles and 2 inch drop springs, drop springs, new control arm bushings upper and lower, ball joints, tie rods ect.. Front is great, BUT
Did the rear today, Flip kit, rear shackles, shock extender and drop shocks, Have a heavy half 75 C-10. Took the helper/overload spring off put new bushings in the leaf springs, installed the shock extenders and drop shocks as well as shackles. put wheels on dropped it down, bump stops on the axle, No suspension. Jacked it back up put the leaf in the 1st position of the shackle, dropped it down looked like i had 1/4 inch from bump stop to frame, jumped on bumper, bump stop back on axle. I took before and after measurements and i am only dropped a little under 5 inches. If i remove the whole bump stop assly i would only have 2.5 inches if it doesn't drop anymore once the bump stop is off the axle. I was hoping to avoid any kind of notch.. Is there anything else i can do here? Thanks
Grandpas and Dads and now my 1965 C-10
1975 SWB C-10
Bennydog is offline   Reply With Quote
Old 07-30-2017, 11:24 AM   #2
SkinnyG
SkinnyG's Avatar
Re: Rear flip kit bump stop ?
1) I think your u-bolt mount is on upside down. I think the angled ends should be pointing down.
2) Remove the factory bumpstop completely.
3) Energy Suspension makes a wee bumpstop that you can put in its place, part number 9.9132 (3/8″ thick) which will work for you. I ran with zero rear bumpstops at all for the past ten years.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-30-2017, 12:37 PM   #3
bbbc10
Diggin The SquareLife
Your bottom bracket is upside down might wana fix that.....also the lowest you can go without a notch is 6" an thats if you dont tow or haul with it. so you have flip kit that gives you 5" plus shackes....set the shackles at 1" drop. Remove bumpstop an get some aftermarket ones
bbbc10 is offline   Reply With Quote
Old 07-30-2017, 04:01 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Yes to all the above, I would put the original shackle bracket back on, mine looks exactly like yours with no problems, only time the frame and axle came in contact is when I hauled a pallet of ceramic tile home from Lowes, thankfully I live only a 1/4 mile away
Malo83 is offline   Reply With Quote
Old 07-30-2017, 04:13 PM   #5
Bennydog
Bennydog's Avatar
Thank for the replies, I am going to remove the factory bumpstop, Hopefully I am not banging on the frame. The truck already had a drop shackle so I do not have the originals so I will look for a set of stock shackles. Would taking off more leafs help give me a little clearance?
1975 SWB C-10
Old 07-30-2017, 06:41 PM   #6
SkinnyG
SkinnyG's Avatar
Taking leafs out will give you less clearance, because there are less leafs holding the truck up.
Old 07-30-2017, 10:03 PM   #7
Bennydog
Bennydog's Avatar
Flipped the bottom bracket over and grinded off the damn rivets holding on the bump stop brackets.. Have some clearance now. Still rides pretty poorly, Thought it would be much better with all new bushings, ball joints, springs, shocks ect..
1975 SWB C-10
Old 07-30-2017, 10:52 PM   #8
SatinSeventy2
May not ride great, but sure looks good!
SatinSeventy2 is offline   Reply With Quote
Old 07-31-2017, 12:13 AM   #9
SkinnyG
SkinnyG's Avatar
Are you getting any axle smacking the frame?
A flip kit AND longer shackles is a lot of drop.
Old 07-31-2017, 01:19 AM   #10
Malo83
Cruzzzn' Vet
Malo83's Avatar
x2,
Old 07-31-2017, 08:30 AM   #11
Rich84
Rich84's Avatar
Maybe a dumb question but..When you use shock extenders aren't you supposed to use regular length shocks not drop shocks?
Rich84 is offline   Reply With Quote
Old 07-31-2017, 09:24 AM   #12
RWJJR
RWJJR's Avatar
Looks great, I just done tha same setup on mine!
1980 Silverado short bed
1993 GMC 1500 LS swap
2006 Lifted Z71 Crew Cab
RWJJR is offline   Reply With Quote
Old 07-31-2017, 09:57 AM   #13
blazer2007
reg. length from what I,ve read and that,s what I have.
blazer2007 is offline   Reply With Quote
Old 07-31-2017, 11:00 AM   #14
SCOTI
SCOTI's Avatar
You're supposed to be able to use regular length replacement shocks but it all depends on the trucks combination of parts. I've had to run a shorter shock on more than one truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-31-2017, 11:15 AM   #15
Bennydog
Bennydog's Avatar
the "KIT" I got from Western Chassis came with both shock extenders and drop shocks...
1975 SWB C-10
Old 07-31-2017, 12:44 PM   #16
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice looking ride.
Old 08-02-2017, 10:06 PM   #17
Dads79GMC
Dads79GMC's Avatar
I would imagine that those are 56" springs and possibly original; so there may be some sag in those old springs which will also drop you a little lower. I replaced my 7/1 (could have been 8/1) springs with new ones, took out the overload spring and one normal spring and I sit about five inches off the axle. I bought a round 2" or so bump-stop from summitt. All should be well. Thanks Mike
Note: I also put the original shackles and hanger back on during my flip.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 08-02-2017, 10:17 PM   #18
Dads79GMC
Dads79GMC's Avatar
Here's a pic. -We basically have the exact same set-up. Keep in mind, I do not have the floor in the pic of the truck, so it's up slightly in the back. Thanks Mike
Old 08-03-2017, 10:44 AM   #19
Tash4
Tash4's Avatar
Nice truck. as Malo said put stock shackles back on. we used stock shackles & springs then took rubber bumper off.
Tash4 is offline   Reply With Quote
Old 08-03-2017, 02:09 PM   #20
Tom
driving is in my blood
Tom's Avatar
Or just do a c-notch.
Old 08-03-2017, 03:31 PM   #21
Shugalou
Shugalou's Avatar
I'm in a similar predicament. I installed a belltech 4/6 kit and the rear frame was resting on the axel, I ended up taking the leafs to a spring shop and had them add an inch of arch and another thin leaf - hoping to have back together tonight.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 08-03-2017, 05:46 PM   #22
bbbc10
did you see where he said he wanted to avoid doing a notch
