Not sure what this is called
Can anyone tell me what this is called? Pulled it from the ignition area.
![]() Join Date: Mar 2003
Re: Not sure what this is called
That would be your ignition switch supposed to bolt to the column and actuated by a rod from the lock cylinder
thanks!
and its adjustable as you can see on the 2 slotted mount holes . so your key moves the rod just the right amount.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
