Re: Spark Plugs What is wrong?
Timing!!
What's initial timing? |
What's the gap on the plugs?...should be 45
1970 C10 Short Stepper with 71/72 front clip. |
Do a leak down test sounds more like a mechanical issue. Also check and make sure that the power feed for the distributer is a full voltage and not the factory resistance wire.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
Moderator
![]() Join Date: Jun 2017
Cyl 3,4 and 6 all look like water contamination within the combustion chamber...
Compression test and leak down test...most likely blown head gasket between 4 and 6... Could also be a lean out due to manifold crack...is this a two barrel or four barrel carb? Open plenum manifold or closed ? |
![]() Join Date: Dec 2013
I would get a correct set of matched plugs gapped correctly and run it again before you get too crazy trying to diagnose whats wrong , the threads don't even look the same length let alone the heat range can't be the same .
I had all the same at first...they looked fouled so bought all new ac plugs at beginning...no difference...then this last try...I put in the 3 autolites...still ran the same.
#7 | |
bought truck from....carbs are not the problem both that I have tried run perfect on my other truck. |
